jibby
- 857
- Santa Monica, Ca.
Ok, I have been thinking of ways to make my car faster 0-60mph without hp gains and reducing the weight on my sc400/Soarer was one of the ways, I am hoping to drop 300lbs but so far I could only come up with these:
1) removing the spare tire and rim, jack, and tools from the trunk and replaced them with a bottle of fix a flat -60lbs,
2) carbon fiber hood -40lbs,
3) Stock fan and components -20lbs
I just reduced the cars weight by 110lbs that is almost like another person riding in the car with you... anyway I am going under the car tomarrow to look at the underbody, framing, floor boarding, backing, etc... and see what can be removed or modified for weight reduction without danger. Even Steel to Aluminum..etc.. if anyone can add to that above list I would be grateful for any suggestions, just don't say remove the a/c...:slaphappy
Other ways I have gained speed 0-60mph is by reducing my rear wheel size from 255 to 235's on my 18's and also using light weight alluminum rims compared to stock and others and the combination has helped I believe. Lighter weight at the wheels and smaller tire diameter all play into the equation of gaining speed 0-60mph, believe it or not. More dramatic results would also be from improved differential gearing to increase power to those rears.... Searching for ways to increase speed that have nothing to do with the engines power output or tranny. I really think these topics or over looked on these forums... just throwing suggestions out there that are effective for speed increase which we all want....
