- 4,791
- Houston, TX
Fasteddie, can you (or anyone else) confirm the 3SGTE has, (or had) a shim under bucket arrangement, and 6mm valve stems?
If so, that should be a very clean solution. I was informed by both Manley and Supertech that the RB26 retainers were the only "shim under" type available for 6mm valve stems.
Pics of the retainers, shims, and their P/N's would be fantastic.
(I'm just about to pull the trigger on 32 titanium retainers for the RB26 from Manley, and I'll probably have to source the shims from Oz, so if there's an easier (read: Toyota) solution, let's have it!)
