There's also the minor difference of right hand drive.
IS200 Specification & prices
This page provides an overview of IS200's impressive technical performance data. Click here to enter the Lexus Technology section, for more detailed information about Lexus engineering and design features.
Click here to view the UK prices for the IS200.
Performance & Fuel Consumption
Maximum Speed: Manual: 134 mph
Auto:127 mph
Acceleration 0-62 mph(0-100 km/h): Manual: 9.5 sec
Auto: 11.2 sec
Fuel Consumption
Urban: Manual: 21.4 mpg
Auto: 20.2 mpg
Extra-urban: Manual: 36.2 mpg
Auto:36.7 mpg
Combined: Manual: 29.1 mpg
Auto:28.5 mpg
CO2 emissions: Manual: 231 g/km
Auto: 237g/k
Compression Ratio: 10.0:1
Dimensions & Weight
Dimensions
Length: 4400 mm
Width: 1725 mm
Height: 1420 mm
Wheel base: 2670 mm
Fuel tank capacity: 70 litres
Luggage compartment capacity: 400 litres
Gross vehicle weight
Front: Manual: 880 kg
Auto: 890 kg
Rear: Manual: 950 kg
Auto:940 kg
Total: Manual: 1830 kg
Auto: 1830 kg
Maximum permissible axle capacity
Front: 1055 kg
Kerb weight
Kerb Minimum: Manual: 1380 kg
Auto:1385 kg
Kerb Maximum: Manual: 1455 kg
Auto:1455 kg
Wheels and tyres
Wheel size: 6.5JJ x 16"
Tyre size: 205/55R16"
Towing capacity
With brake: 1200 kg
Without brake: 450 kg
Chassis & Body
* Rigid high-tensile steel cabin cage
* Extensive anti-corrosion protection
* Super-high quality finish featuring multi-layer paint treatment
Exterior
* 16" alloy wheels with locking wheel nuts
* Electrically heated and foldable outside rear view mirrors
* Front fog lamps
* Immobiliser
* Double locking
* Stainless steel exhaust pipe finisher
Engine & Transmission
* 2-litre engine
* VVT-i - Variable Valve Timing - intelligent (electronically controlled)
* ETCS-i - Electronic Throttle Control System - intelligent: advanced computerised engine management system
* 6-speed manual transmission or 4-speed Electronically Controlled Transmission (ECT-i) with intelligent computer control
* AI shift system
* Dual stainless steel exhaust system with catalytic converters
Cylinders/valves: in line 6/24
Capacity: 1988 cc
Compression ratio: 10.0:1
Stroke/Bore: 75.0 x 75.0 mm
Maximum output: 153 bhp (114 kW) @ 6200 rpm
Maximum torque: 144 lb/ft (195 Nm) @ 4600 rpm
Suspension, Braking & Safety Systems
Suspension
Front: Double wishbone
Rear: Double wishbone
Brakes
Front: Ventilated disc
Rear: Solid disc
Safety
* Driver and front passenger airbags
* Front seats side airbag system, with curtain shield front airbags
* Seat belts with pre-tensioners and force limiters
* Traction Control System (TRC)
* Electronic Brake force Distribution (EBD)
* Brake Assist (BAS)
* Anti-lock Braking System (ABS)
Interior
* Fabric upholstery
* Tilt-adjustable steering wheel
* Chronograph style instrument
* meter design
* Drink holders front and rear
* Floor mats
* Front armrest (automatic transmission)
* Metallic gear shift knob
* Electric windows with anti-jam protection and one-touch auto up/down feature on driver's side
* Climate-control air conditioning Cruise control (automatic transmission)
Audio
* 6-speaker stereo hi-fi system
* 3-wave-band RDS radio with 18 pre-set channels and Dolby cassette
* 6-disc CD autochanger
http://www.lexus.co.uk/specification.php?model=is&variant=200&area=specification
