HELP!!! PLEASE HELP! MY CAR IS DEAD AND I DONT KNOW WHY!
So i was on the interstate and my battery light came on. It started flickering on and off then it stayed lit. When I got home it died on me and I plugged up the charger, but it said it was 100% done! So i checked my connections and they are all good. Then I started it and it was fine. Then I went somewhere, came back home and started it up and it was revving out of control. It was staying betweer 3 and 4 RPM's. the throttle is not stuck or anything like that. my car has gone insane.
I have a 95' SC400. It has 250,000 miles on it
Interesting problem.... Perhaps you should stay out and dont go home. That might solve your problem. JK.... lol .. I would suggest double check your alternator and relays.
you need a young priest and an old priest...
check all your input sensors are plugged in properly. Mind you, I wouldnt think it would rev that high with the butterfly closed?
I'm not too sure the ls has an idle air controll valve but if it does most likely thats the cause of the erratc revs and idle. And check your relays
