HELP! Need another Engine ECU
Glider
Hi all,
Been searching for months for another Engine ECU 89661 50250 just thought I would ask if anyone on here had one knocking around on a shelf in the back of a garage collecting dust somewhere in the world
Many thanks
Phil
gloverman
Well-Known Member
ok. LS400 ecu arent so common over here. I often swap in celsior ECU but there are other things to consider when doing so. Just did one recently
Glider
Got a g
Hi again,
Got a guy with a 93-94 LS400 ECU No. 89661-50180 would you have any clue on what other ECU part numbers I may be able to use please
many thanks
Phil
gloverman
Well-Known Member
Got a g
Hi again,
many thanks
Phil
Hello. Is it in an ls400 or a conversion. Numbers from 150-180 can be used in most cases.
Glider
Hi thanks for taking your time out to help,
Its NOT a conversion, its a LS imported from Hong Kong and is a bit of a rare thing so it seems (has JDM lights on the back like the Celsior, but has all Lexus badges and steering wheel etc - but it does not have traction control or heated seats).
is what the gentleman told me about the car, its a 1993
any guidance is very welcome
Many thanks
Phil
gloverman
Well-Known Member
I did a swap recently of a ucf20 ls400 ecu to celsior. Video here
It resulted in the egr being turned off without codes and a code behind for hydraulic fan. Car ran fine and code didnt result in check light.
Have you not got a good ECU rebuilder you can use? I would be happy enough to swap to a celsior ecu however I have the advantage of trying one first as I keep a test ecu from each ecu range. Cheers.
Glider
The guy informed me that he is having the caps changed and ECU checked by a ECU specialist we will see how he gets on.
your brilliant by the way, thanks again for your precious time and your knowledge
Kindest regards
Phil
