Delica l400
Fitted with 285/75's. Took a bit of manipulation to the inner guards to get them to fit but they're on. :)
Final assembly done and exhaust finished.
Flexible intake tube is not ideal but is functional and will do the job till I can get a custom airbox made up.
All fluids in and no leaks. :)
Next stop-Kelvin will work his magic on it.
Now that it's running theres a lot more to do.
AVIS solenoid that sits under the intake manifold doesn't work so it's a bit gutless down low. So Manifold has to come off(Should have listened to Kelvins sage advice in his vid and done that job before putting the engine in the van:rolleyes:).
Oxygen Sensor in the exhaust is faulty so it's dumping 20% more fuel on one side. Have to pull the battery tray and pipes out to get the manifold out as the sensor is seized in there.
I left the Diesel muffler on it because I wanted to keep it quiet but it's too restrictive for the V8. A bit like trying to blow through a straw.
Good thing I've got a few weeks of annual leave coming up. I'll be able to get stuck into it.
