This is just an interem thought for me untill I go standalone eventually. My current boost set up means I need to run the MAF, but it doesn't seem to like boost.
The problem for me running pull through is there's no room for the big housing. I was just thinking though, if I eliminate most of the housing so there's little more than the black sensor itself (length wise) I would be able to squeeze it in.
Will this void the readings of the MAF? I have heard of people removing the honeycomb section, this wouldn't be much different, i'd just be removing the actual cast housing from both ends too....
