crown auto to w58 5, speedo readings?
deankdx
geelong, Victoria, Australia
i have in my car a ten pulse/rev transducer running both auto and speedo off the crown speedo output,(i think the speed sensor input is on the ABS? input i don't know but it works so i'm not touching it i know it should be 4 pulse to somewhere else?)
what i'd like to know is if the ratio of that speedo drive is the same from the crown auto to W58, it would save me clibrating my speedo if i do a swap(just happened to fluke having only2.5% speedo error at 100kmh)
also has anyone got accurate trans wiring diagrams for the 4 pulse transducer as i may have anothrer crack at doing it properly(always goes into overdrive even if switch is off and on power mode it hits the rev limiter)otherwise it works fine in econ and shifts at full throttle at 5800rpm.
