Converting to air suspension ls400
Di0n
Northland, New Zealand
I recently bought a 1990 ls400. It's completely stock with coil suspension. I want to lower it quite a bit and have been given a full factory air suspension setup. Now the problem is my car has no wiring for the air suspension. I plan to set it up like factory but have the factory valves on switches and get rid of the self leveling bits. Can anyone help with how I can wire it up? Does the compressor just need power and earth with a switch?
air suspension
hi Dion You might find this a help,i used it to fix my SC400 air when i got my car, as you can see you will need the suspenion computer, and there is a lot of wires into that alone. you will also need all the suspenion height sensors etc it would be a nightmare to get going without a factory loom.
http://www.lextreme.com/as.pdf
Regards
Graeme
I have decided to set it up using the factory bags but aftermarket valves and lines with switches in the cabin just like an aftermarket setup. I'll keep you posted.
