Can't pull codes
Gator3
I'm putting the jumper wire in Te1 and E1 to check codes on my 1993 LS 400; have12.5 volts, have it neutral, AC off, throttle valve closed as far as I can tell, and turn the ignition on but check engine light does not do anything but stay lit.
Car has a real lack of power, and I hear a clicking on the D/S fuel rail toward the back where there is a vacum looking partis in the fuel line. I have a mechanics stethoscope and that is where it is the loudest. This sound just started yesterday when my check engine came on.
Any body got any ideas as to what I can do to check codes?
Many thanks in advance. Scott
Deepa
Are you starting the car? Jumper the terminals and make sure a good half inch of the paperclip or whatever is inserted into the diagnostics plug. Then turn your car to the IGN position but don't crank it over. Should work.
George_R
USDM cars don't have the feature to pull codes by shorting the pins, only toyota scanner works with them. At least this is true for LS430.
taka21
i have found that as long as the car is obd2 you can just scan it, if its a swap and you used the obd 2 wiring you just have to wire in the obd2 port, i did and it works beautifully
George_R
pre-obd2 cars are also scanable, of course you need to wire everything correctly.
I came across a few USDM LS430's, they only could be read with scanning software. No TC to E1 trick. (surprisingly they are popular here)
