Big
- 376
- New Zealand,Queenstown
OK here's update..I'm a little stuck with the diagrams..the wiring colours are different and all i need to get is the ecu power,ignition feed and injector feed..I think I have everything else right but with only essentially 1 plug cut..i'm hoping that all you genius's can point me in the right direction..(I'm no auto electician-just your joe average master of 1 and play with everything else..only way to learn..hehe)
Plug A and B plugged into what? not too sure..
Instrument cluster plug I have got temp,oil sender feeds..anything else I've missed?does a ignitor feed for tacho come to same place?
The cut wires..I'm assuming that these used to goto ignition switch etc..as the ignition wire(fat B/R) is cut and goes to near ignitors are-the 3 pin plug..also the same plug you use for the soleniod to starter motor..
There is 2 wires cut(both lime green sort of colour)and come out next to AFM plug..and cut there too..what are these for?have I missed anything..?
Any help,pointing in the right direction would help lots..Cheers Keri
