- 4,791
- Houston, TX
This is the AEM cal file Mitch Pederson developed on the engine dyno in October of 2008. The motor made 498 HP @ 6900 RPM, with mistimed cams.
It has a very aggressive ignition map which is not suitable for pump gas. We did all our testing on C14 and C16 race gas.
Engine: Early 1UZ, no VVTi
Injectors: 460cc Denso
Cams: Lextreme Stage 1
FI: Opcon Autorotor twinscrew supercharger
Ignition: COP using Tundra coils
Intercooling: Methanol injection - see notes below
Standard 12 tooth trigger wheel used for crank trigger
Left bank (only) cam trigger was used, and is on input G1, (B26)
This was a standard Gen1 AEM for the Toyota Supra with a few configuration changes as per below.
I/O Configuration Notes:
Coil 4 output (A22) is used to fire cylinders 2 & 3
Injectors 1-6 are wired normally, Injector 7 is on B70, Injector 8 is on B13.
Injector 9 (B74) is used for PWM control of methanol injection
LS9 (B68) is used for electric radiator fan control
Injector 10 (B75) is used for PWM control of the fuel pump
LS1 (B61) is used to tell a Kenne Bell BAP to switch from 14 to 18 volts
PW2Out (B62) is used for boost control
HS2 (A30) is used for methanol on/off enable.
Note: Since Coil4 (normally used for Fuel Pump Control) is now used to fire the ignition coils for cylinders 2&3, HS1 (A8) could be used for fuel pump control (not currently enabled in this file)
