E elliotaw New Member Messages 221 Location Melbourne, Australia Sep 17, 2005 #1 Can anyone help with a wiring diagram for the A341e transmission? Found a link on the forum but it's not working at the moment. Elliot
Peewee New Member Messages 2,635 Location Perth, Western Australia Sep 17, 2005 #2 Need anything else?
E elliotaw New Member Messages 221 Location Melbourne, Australia Sep 18, 2005 #3 Err yeah, a lot of help from above looking at how many wires are with the new tiptronic controller ! I'm a bit of a dummy when it comes to auto electrics, so need as much help as possible. On those two connectors, what does each wire do? or do you have a more descriptive version for the connections? I have 5 plugs on my transmission. Do you have details for the other 3 also ? Elliot
Peewee New Member Messages 2,635 Location Perth, Western Australia Sep 18, 2005 #4 S1, S2, S3, S4 are the 4 solenoids. (S3 might be labelled as SLU-) (S4 might be labelled as SLN-) B+ = 12v Ignition That is the 6 pin plug at the rear P = Park R = Reverse N = Neutral D = Drive 2 = Second L = Low B+ = 12v Ignition NSW are the 2 wires for Neutral safety switch. That is the plug on the selector stalk. The 2 pin one at the front of the box is NCO+ and NCO- If its a Crown box then the 3 wire that bolts to the tranny is SP2 And the other 3 wire that screws in is the speedo.
R Rusty New Member Messages 63 Location Hamilton NZ Sep 19, 2005 #5 Need a little help, I have got a Pricol Programmable Speedometer and a 1990 crown motor & trans. I was hoping that you would know what or how these go? Which one of the three wires from the sensor is the output?
