Jgrov2
- 16
- Arana hills
I’ll try and post videos of the revs and idling plus what little data I could extract from live data ecu.
I’ve put 3uz from Celsior into 96 hilux. Its usually hard to start both hot and cold and sometimes idles fine sometimes rough. Biggest issue is the throttle. Revs usually drop until it’s 30% in then they pick up and act normal it will rev out to limit. If I let them drop to idle it will act crap again and sometimes stall out in neutral.
I’ve ditched the auto and running manual gearbox with no emulator yet. I’ve put new plugs in clean maf and new Vvti sensors as I leaned on them and broke them. It’s not throwing any codes except for missing trans, fuel circuit , stop light and secondary o2 sensors.
My fuel pressure is up at 4.5bar as all I had laying around was 4.5bar Audi unit. I’m waiting on adjustable fpr. What else should I be looking at in the mean time as the car is pretty undrivable/unpredictable especially trying to use clutch and dodgy accelerator. Below is pic of engine bay and don’t worry vacuum hoses are sorted and connect just off during work and pic.
