Ok, over the last couple of days, me, my mechanic and my engine builder have been seating down and reviewing this supercharger setup and engine combo.
The engine builder is not too confident with the supercharger belt setup.
“I think my engine builder now’s a thing or 2, as he builds blown 10ltr drag boat engines producing over 3000+hp”that’s a lot off ponies.
My engine builder said, that with the boost that im running an the engine setup, I should have the following
- a tooth belt, as the rib belt will spin running 20psi+
- new pulleys to suit belt
- a brace to support blower snout
- Fixed bolted belt tension system instead of spring loaded 1
- new tension plate with welded mounting points
I going ahead and having the changes done locally instead of shipping the items back to Andrew to be modified.
This process saves me time, by the time I disassemble and send back, then wait for work to be done and have shipped back, that can be a month or more, this way I can have all the work done within a week as the engine builder is around the corner from the workshop where the car is.
The whole engine combo (semi dressed engine with blower) will be sent around to the engine builder, we he will do all the changes to the system.
Then after when the engine is fitted in car, an my mechanic is ready to tune it on the dyno, the engine builder will be there during the tuning process to make sure all is ok.
With the little hiccups that we have had now, this has set the project back by 3 to 4 weeks now (car was planned to be on the road running November 1st finished) and I’m just starting to wonder if I can have all this done, and have the engine run in by Christmas time now, For the Summer Nat’s (Last week of December)
