2001 Lexus GS430 Immobilizer Delete, Power Q's
QuasiMofi
Is there an "easy button" immobilizer delete for the 01 GS430?
If the wheel sensors are all removed from the system will the ECU limit power?
Does the ECU Power ECON button need to exist? Can it be hotwired into Power only?
I would love to be able to have it all programmed out of the ECU as well as the downstream O2s but even if it came to routing a resistor in a loop on the ECU or wiring the switch circuit closed would be okay.
The engine, automatic transmission
