Hey guys this is a message for Sideshow as he did the wiring conversion on my 1UZ boat, but I will put it out there for all for future reference.
Everything was working perfectly on the boat and was extremely reliable, I had to replace the steering ram so had to take all the cowling out and disconnect the batteries.
Anyway everything went back the same way, however I found that when you went for a start, the fuel relay would engage the fuel pump as normal and then on the start the starter motor would click and then everything would just die.
No gauges, no ignition like the battery would be dead flat.
Anyway upon looking at the relays in Sideshows wiring I would notice the ECU relay would madly flicker until you disconnect the battery.
Then after 1 min you would connect the battery as normal and all gauges and fuel pump etc would do their thing ready for a start.
Im at a loss as to why its suddenly doing this, I have tried different relays, swapping them, I even have 3 spare ones i have tried same thing...
Any ideas anyone?
Any ideas anyone?
