1UZFE/2UZFE into a 2nd Gen 4Runner (U.S.)
I am hoping to remove my 1" BL, but I'm still not sure that can happen yet. Going for low and planning to hack my fenders/footwells.
(like my shim?)
Did another trial fit of the oil filter mount. Framerail clearance is an issue.
On the left is the 1UZ filter on the right, the 3VZE. Neither of them make it.
Looks like a relocation or more of a block hugger mount is in order.
Not sure yet, but it appears that the stock steering stabilizer location can be reused. Might be tight with the beefy OME though.
I usually just re spray the part...great pics i will be hopefully starting my swap soon i am going to opt out of the 4.3 vvti and go with the 4.0 it just seems like less of a hassel...
That is a great move. There is much more knowledge available for the 4.0 currently. 3-4 years down the road will be another matter entirely...
This is an awesome thread guys..currently thinking of a 1UZ into a Pajero..any ideas,thoughts? found a thread on http://honda-tech.com/zerothread?id=793066 but the link is broken and is very old.. :( anyways just trying to collect as much info as poss.. :) btw the A44DL atm is same as in V6 pajero's so a bellhousing is most likely too ..might be able to keep original running gear..anyone thinking of the same?
Whoops..lol found out it the wrong box BUT the A340F IS in the Pajero/Montero 3.0 ltr and 3.5 ltr version from 94 onwards...it a start looks like i just need to change the bellhousing and The oil pump drive ,input assembly if I'm right thats it as well as maybe doing the Valve body mod( do i really need to..?) thats should be all oh i'm not goiung to use the rocks gearing so is standard T'case OK..? ie strong enough..?if so then it should ( 1UZ + Modded Hybrid A340F) just fit straight in with mayb e a BL 1-2"..hope so:) also have to find the rear sup verison to make it a better swap.Heard that front sups can do the mani bearings when climbing hard..Vertical..Oil drains from front to back then Boom she's a gonna,no more oil on bearings etc..What do you guys think..? It's a goer i know..:)BTW in New Zealand and i want to have the first 1UZ Pajero in the country..hehehe keep ya posted on wuts goin on
Cheers K
A340F ATM's
Complete list of Vehicles they are manufactered in and Year..Hope this helps
Select Transmission: A340F
4-SPEED RWD, 4X4
Select Manufacturer:
Select Model:
Make Model Year SubModel ET L CC CID F FD ED E-VIN ASP
JEEP CHEROKEE 1987 L4 2.5 150 GAS FI H N
JEEP CHEROKEE 1987 CHIEF L4 2.5 150 GAS FI H N
JEEP CHEROKEE 1987 LAREDO L4 2.5 150 GAS FI H N
JEEP CHEROKEE 1987 PIONEER L4 2.5 150 GAS FI H N
JEEP CHEROKEE 1987 PIONEER L6 4.0 242 GAS FI M N
JEEP CHEROKEE 1987 LAREDO L6 4.0 242 GAS FI M N
JEEP CHEROKEE 1987 LIMITED L6 4.0 242 GAS FI M N
JEEP CHEROKEE 1987 CHIEF L6 4.0 242 GAS FI M N
JEEP CHEROKEE 1987 L6 4.0 242 GAS FI M N
JEEP CHEROKEE 1988 PIONEER L4 2.5 150 GAS FI H N
JEEP CHEROKEE 1988 CHIEF L4 2.5 150 GAS FI H N
JEEP CHEROKEE 1988 LAREDO L4 2.5 150 GAS FI H N
JEEP CHEROKEE 1988 L4 2.5 150 GAS FI H N
JEEP CHEROKEE 1988 L6 4.0 242 GAS FI M N
JEEP CHEROKEE 1988 LAREDO L6 4.0 242 GAS FI M N
JEEP CHEROKEE 1988 LIMITED L6 4.0 242 GAS FI M N
JEEP CHEROKEE 1988 CHIEF L6 4.0 242 GAS FI M N
JEEP CHEROKEE 1988 PIONEER L6 4.0 242 GAS FI M N
JEEP CHEROKEE 1989 PIONEER L4 2.5 150 GAS FI E N
JEEP CHEROKEE 1989 L4 2.5 150 GAS FI E N
JEEP CHEROKEE 1989 LAREDO L4 2.5 150 GAS FI E N
JEEP CHEROKEE 1989 LAREDO L6 4.0 242 GAS FI L N
JEEP CHEROKEE 1989 LIMITED L6 4.0 242 GAS FI L N
JEEP CHEROKEE 1989 L6 4.0 242 GAS FI L N
JEEP CHEROKEE 1989 PIONEER L6 4.0 242 GAS FI L N
JEEP CHEROKEE 1990 L4 2.5 150 GAS FI E N
JEEP CHEROKEE 1990 L6 4.0 242 GAS FI L N
JEEP CHEROKEE 1990 LAREDO L6 4.0 242 GAS FI L N
JEEP CHEROKEE 1990 LIMITED L6 4.0 242 GAS FI L N
JEEP CHEROKEE 1990 PIONEER L6 4.0 242 GAS FI L N
JEEP CHEROKEE 1990 SPORT L6 4.0 242 GAS FI L N
JEEP CHEROKEE 1991 L4 2.5 150 GAS FI P N
JEEP CHEROKEE 1991 L6 4.0 242 GAS FI S N
JEEP CHEROKEE 1991 BRIARWOOD L6 4.0 242 GAS FI S N
JEEP CHEROKEE 1991 LAREDO L6 4.0 242 GAS FI S N
JEEP CHEROKEE 1991 LIMITED L6 4.0 242 GAS FI S N
JEEP CHEROKEE 1991 SPORT L6 4.0 242 GAS FI S N
JEEP CHEROKEE 1992 L4 2.5 150 GAS FI P N
JEEP CHEROKEE 1992 L6 4.0 242 GAS FI S N
JEEP CHEROKEE 1992 BRIARWOOD L6 4.0 242 GAS FI S N
JEEP CHEROKEE 1992 LAREDO L6 4.0 242 GAS FI S N
JEEP CHEROKEE 1992 LIMITED L6 4.0 242 GAS FI S N
JEEP CHEROKEE 1992 SPORT L6 4.0 242 GAS FI S N
JEEP CHEROKEE 1993 L4 2.5 150 GAS FI P N
JEEP CHEROKEE 1993 L6 4.0 242 GAS FI S N
JEEP CHEROKEE 1993 COUNTRY L6 4.0 242 GAS FI S N
JEEP CHEROKEE 1993 POSTAL L6 4.0 242 GAS FI S N
JEEP CHEROKEE 1993 SPORT L6 4.0 242 GAS FI S N
JEEP CHEROKEE 1994 SE L4 2.5 150 GAS FI P N
JEEP CHEROKEE 1994 SE L6 4.0 242 GAS FI S N
JEEP CHEROKEE 1994 SPORT L6 4.0 242 GAS FI S N
JEEP CHEROKEE 1994 COUNTRY L6 4.0 242 GAS FI S N
JEEP CHEROKEE 1994 POSTAL L6 4.0 242 GAS FI S N
JEEP CHEROKEE 1995 SE L4 2.5 150 GAS FI P N
JEEP CHEROKEE 1995 SE L6 4.0 242 GAS FI S N
JEEP CHEROKEE 1995 SPORT L6 4.0 242 GAS FI S N
JEEP CHEROKEE 1995 COUNTRY L6 4.0 242 GAS FI S N
JEEP CHEROKEE 1995 POSTAL L6 4.0 242 GAS FI S N
JEEP CHEROKEE 1996 SE L4 2.5 150 GAS FI P N
JEEP CHEROKEE 1996 SE L6 4.0 242 GAS FI S N
JEEP CHEROKEE 1996 SPORT L6 4.0 242 GAS FI S N
JEEP CHEROKEE 1996 CLASSIC L6 4.0 242 GAS FI S N
JEEP CHEROKEE 1996 COUNTRY L6 4.0 242 GAS FI S N
JEEP CHEROKEE 1996 POSTAL L6 4.0 242 GAS FI S N
JEEP CHEROKEE 1997 SE L4 2.5 150 GAS FI P N
JEEP CHEROKEE 1997 SE L6 4.0 242 GAS FI S N
JEEP CHEROKEE 1997 SPORT L6 4.0 242 GAS FI S N
JEEP CHEROKEE 1997 COUNTRY L6 4.0 242 GAS FI S N
JEEP CHEROKEE 1997 POSTAL L6 4.0 242 GAS FI S N
JEEP CHEROKEE 1998 L4 2.5 150 GAS FI P N
JEEP CHEROKEE 1998 L6 4.0 242 GAS FI S N
JEEP CHEROKEE 1999 L4 2.5 150 GAS FI N
JEEP CHEROKEE 1999 L6 4.0 242 GAS FI N
JEEP COMANCHE 1987 L6 4.0 242 GAS FI M N
JEEP COMANCHE 1987 CHIEF L6 4.0 242 GAS FI M N
JEEP COMANCHE 1987 LAREDO L6 4.0 242 GAS FI M N
JEEP COMANCHE 1987 PIONEER L6 4.0 242 GAS FI M N
JEEP COMANCHE 1988 L6 4.0 242 GAS FI M N
JEEP COMANCHE 1988 CHIEF L6 4.0 242 GAS FI M N
JEEP COMANCHE 1988 ELIMINATOR L6 4.0 242 GAS FI M N
JEEP COMANCHE 1988 LAREDO L6 4.0 242 GAS FI M N
JEEP COMANCHE 1988 PIONEER L6 4.0 242 GAS FI M N
JEEP COMANCHE 1989 L6 4.0 242 GAS FI L N
JEEP COMANCHE 1989 ELIMINATOR L6 4.0 242 GAS FI L N
JEEP COMANCHE 1989 PIONEER L6 4.0 242 GAS FI L N
JEEP COMANCHE 1990 L6 4.0 242 GAS FI L N
JEEP COMANCHE 1990 ELIMINATOR L6 4.0 242 GAS FI L N
JEEP COMANCHE 1990 PIONEER L6 4.0 242 GAS FI L N
JEEP COMANCHE 1991 L6 4.0 242 GAS FI S N
JEEP COMANCHE 1991 ELIMINATOR L6 4.0 242 GAS FI S N
JEEP COMANCHE 1991 PIONEER L6 4.0 242 GAS FI S N
JEEP COMANCHE 1992 PIONEER L6 4.0 242 GAS FI S N
JEEP COMANCHE 1992 L6 4.0 242 GAS FI S N
JEEP COMANCHE 1992 ELIMINATOR L6 4.0 242 GAS FI S N
JEEP GRAND CHEROKEE 1993 L6 4.0 242 GAS FI S N
JEEP GRAND CHEROKEE 1993 LAREDO L6 4.0 242 GAS FI S N
JEEP GRAND CHEROKEE 1993 LIMITED L6 4.0 242 GAS FI S N
JEEP WAGONEER 1987 L6 4.0 242 GAS FI M N
JEEP WAGONEER 1987 LIMITED L6 4.0 242 GAS FI M N
JEEP WAGONEER 1988 LIMITED L6 4.0 242 GAS FI M N
JEEP WAGONEER 1989 LIMITED L6 4.0 242 GAS FI L N
JEEP WAGONEER 1990 LIMITED L6 4.0 242 GAS FI L N
MITSUBISHI MONTERO 1994 SR V6 3.5 3497 215 GAS FI M N
MITSUBISHI MONTERO 1995 SR V6 3.5 3497 215 GAS FI M N
MITSUBISHI MONTERO 1996 SR V6 3.5 3497 215 GAS FI M N
MITSUBISHI MONTERO 1997 LS V6 3.5 3497 215 GAS FI 6G74 R N
MITSUBISHI MONTERO 1997 SR V6 3.5 3497 215 GAS FI 6G74 R N
MITSUBISHI MONTERO 1998 LS V6 3.5 3497 215 GAS FI 6G74 R N
MITSUBISHI MONTERO 1998 SR V6 3.5 3497 215 GAS FI 6G74 R N
TOYOTA 4RUNNER 1995 SR5 V6 3.0 2959 GAS FI 3VZE V N
TOYOTA 4RUNNER 1998 L4 2.7 2694 GAS FI 3RZFE M N
TOYOTA 4RUNNER 1998 V6 3.4 3378 GAS FI 5VZFE N N
TOYOTA PICKUP 1990 L4 2.4 2366 GAS CARB 22R R N
TOYOTA PICKUP 1990 L4 2.4 2366 GAS FI 22RE R N
TOYOTA PICKUP 1990 DLX L4 2.4 2366 GAS CARB 22R R N
TOYOTA PICKUP 1990 DLX L4 2.4 2366 GAS FI 22RE R N
TOYOTA PICKUP 1990 SR5 L4 2.4 2366 GAS FI 22RE R N
TOYOTA PICKUP 1991 L4 2.4 2366 GAS FI 22RE R N
TOYOTA PICKUP 1991 DLX L4 2.4 2366 GAS FI 22RE R N
TOYOTA PICKUP 1991 RN01 L4 2.4 2366 GAS FI A N
TOYOTA PICKUP 1992 L4 2.4 2366 GAS FI 22RE R N
TOYOTA PICKUP 1992 DLX L4 2.4 2366 GAS FI 22RE R N
TOYOTA PICKUP 1993 L4 2.4 2366 GAS FI 22RE R N
TOYOTA PICKUP 1993 DLX L4 2.4 2366 GAS FI 22RE R N
TOYOTA PICKUP 1993 RN02 L4 2.4 2366 GAS FI R N
TOYOTA PICKUP 1994 L4 2.4 2366 GAS FI 22RE R N
TOYOTA PICKUP 1994 DLX L4 2.4 2366 GAS FI 22RE R N
TOYOTA PREVIA 1993 DLX L4 2.4 2438 GAS FI 2TZFE A N
TOYOTA PREVIA 1993 LE L4 2.4 2438 GAS FI 2TZFE A N
TOYOTA PREVIA 1994 DLX L4 2.4 2438 GAS FI 2TZFE A N
TOYOTA PREVIA 1994 LE L4 2.4 2438 GAS FI 2TZFZE A S
TOYOTA PREVIA 1995 DLX L4 2.4 2438 GAS FI 2TZFE A N
TOYOTA PREVIA 1995 LE L4 2.4 2438 GAS FI 2TZFZE A S
TOYOTA PREVIA 1996 DX L4 2.4 2438 GAS FI 2TZFE K N
TOYOTA PREVIA 1996 LE L4 2.4 2438 GAS FI 2TZFZE K S
TOYOTA PREVIA 1997 DX L4 2.4 2438 GAS FI 2TZFZE K S
TOYOTA PREVIA 1997 LE L4 2.4 2438 GAS FI 2TZFZE K S
TOYOTA T100 1993 V6 3.0 2959 GAS FI 3VZE V N
TOYOTA T100 1993 ONE-TON V6 3.0 2959 GAS FI 3VZE V N
TOYOTA T100 1993 SR5 V6 3.0 2959 GAS FI 3VZE V N
TOYOTA T100 1994 L4 2.7 2694 GAS FI 3RZFE U N
TOYOTA T100 1994 DLX V6 3.0 2959 GAS FI 3VZE V N
TOYOTA T100 1994 ONE-TON V6 3.0 2959 GAS FI 3VZE V N
TOYOTA T100 1994 SR5 V6 3.0 2959 GAS FI 3VZE V N
TOYOTA T100 1995 L4 2.7 2694 GAS FI 3RZFE U N
TOYOTA T100 1995 V6 3.4 3378 GAS FI 5VZFE V N
TOYOTA T100 1995 DLX V6 3.4 3378 GAS FI 5VZFE V N
TOYOTA T100 1995 DLX EXC V6 3.4 3378 GAS FI 5VZFE V N
TOYOTA T100 1995 ONE-TON DLX V6 3.4 3378 GAS FI 5VZFE V N
TOYOTA T100 1995 SR5 V6 3.4 3378 GAS FI 5VZFE V N
TOYOTA T100 1996 V6 3.4 3378 GAS FI 5VZFE N N
TOYOTA T100 1996 SR5 V6 3.4 3378 GAS FI 5VZFE N N
TOYOTA T100 1997 V6 3.4 3378 GAS FI 5VZFE N N
TOYOTA T100 1997 SR5 V6 3.4 3378 GAS FI 5VZFE N N
TOYOTA T100 1998 V6 3.4 3378 GAS FI 5VZFE N N
TOYOTA TACOMA 1995 L4 2.7 2694 GAS FI 3RZFE U N
TOYOTA TACOMA 1995 REGULAR CAB L4 2.7 2694 GAS FI 3RZFE U N
TOYOTA TACOMA 1995 REGULAR CAB V6 3.4 3378 GAS FI 5VZFE V N
TOYOTA TACOMA 1995 SR5 V6 3.4 3378 GAS FI 5VZFE V N
TOYOTA TACOMA 1995 V6 3.4 3378 GAS FI 5VZFE V N
TOYOTA TACOMA 1996 L4 2.7 2694 GAS FI 3RZFE M N
TOYOTA TACOMA 1996 REGULAR CAB L4 2.7 2694 GAS FI 3RZFE M N
TOYOTA TACOMA 1996 REGULAR CAB V6 3.4 3378 GAS FI 5VZFE N N
TOYOTA TACOMA 1996 SR5 V6 3.4 3378 GAS FI 5VZFE N N
TOYOTA TACOMA 1996 V6 3.4 3378 GAS FI 5VZFE N N
TOYOTA TACOMA 1997 L4 2.7 2694 GAS FI 3RZFE M N
TOYOTA TACOMA 1997 REGULAR CAB L4 2.7 2694 GAS FI 3RZFE M N
TOYOTA TACOMA 1997 REGULAR CAB V6 3.4 3378 GAS FI 5VZFE N N
TOYOTA TACOMA 1997 SR5 V6 3.4 3378 GAS FI 5VZFE N N
TOYOTA TACOMA 1997 V6 3.4 3378 GAS FI 5VZFE N N
TOYOTA TACOMA 1998 L4 2.7 2694 GAS FI 3RZFE M N
TOYOTA TACOMA 1998 V6 3.4 3378 GAS FI 5VZFE N N
Good Posting! That is great info. Where did you come across that list?
I saw 1 error for sure, but not a huge deal. The 1995 4Runner came with an A340H - diffferent animal than the A340F. Also, the 1996-2002 4Runners came with A340F. The list only calls out a few years...
You might need to add the speed sensor show in the pics above also for the ECU to be happy. In talking with SuperRunner, he seems to think it is not needed.
found the list at http://www.transonline.com/transID/default.asp and i'm sure that it would be around say 90% correct which in turns gives a LOT of people options which is awesome,The site is good in the sence that you can chop and change the manufactorers and double check if it is listed..
sticky+1 i think..:p
Also i'm sure that there would have ben very slight variations of what is listed but generally good info.
Xferr CAse
Am I correct in saying that the xfercase in the A340F is the VF2A..? and if so is it strong enought for a 1UZ chain driven??? also just read that the new Cruiser has this xfer also
quote "Early 2005 - Toyota exhibits the GSJ10/GSJ15 FJ Cruiser as a 2007 model to debut in early 2006. It features bodywork reminiscent of the classic FJ40 and has a boxed frame with solid axle rear suspension and independent front suspension available with a RA61F 6 speed manual, VF4B full-time Torsen 4x4 transfer case, a A750E 5 speed automatic 4x2 or a A750F 5 speed automatic with a VF2A part-time 4x4 transfer case and driven by a 1GR-FE V6 engine. While not a true "Land Cruiser", the FJ Cruiser shares much of its DNA with the proper Land Cruiser line, sharing many parts with the 120 Series "Prado". " end quote..
Would i HAVE to do a gear drive xfer with the A340F..? just getting my info right for a project i've been thinking of for a while now..:):feedback:
A340f
I stand corrected...AW30-40LE is the same as the A340F....bugger it but hey at least i found out now and not after i have got a new truck for my project..lol :smileysex
Here they are..
VOLVO 960 1993 L6 2.9 2917 GAS FI B6304F 9 N
VOLVO 960 1994 L6 2.9 2917 GAS FI B6304F 9 N
VOLVO 960 1995 L6 2.9 2917 GAS FI B6304F 9 N
VOLVO 960 1996 L6 2.9 2917 GAS FI B6304F 9 N
VOLVO 960 1997 L6 2.9 2917 GAS FI B6304F 9 N
Enjoy K
I have a friend with an LS400. I will reach up there this week sometime and disconnect that and go for a drive. I will let you know how it reacts.
That would be awesome! You around Monday for a phone call? Weekends are bad for me due to family obligations...
Not sure, but I think it is a VF2A - I have one out of a 2000 4Runner I'll check.
The only reason I went with the gear drive cases was so I could run crawler gears and a doubler. The other benefit for me was the driveshaft got back on the correct side for my application. The 96-02 A340F are driver side drop.
Monday will probably be bad, Tuesday too. I have viewing and a funeral to go to. Cousin was killed in a car accident(dumb 16 year old just got his license and was traveling down a small canyon at 90mph and hit head on with a suburban. Killed all the passengers in the back seat of the mustang...16 year old kid and front passenger lived. Guys in suburban were fine.
Anyway wednesday would be good. I have some questions for you, and I will try to find out about the sensor before then.
cebby, did you mention that the Tundra manifolds might be a little more narrow?
I just purchased a 2UZ, but i have to wait to get it delivered? Do you know if these will work? If not, then I need to start on a custom manifold.
From what I've seen, the collector may get into the firewall. (See post 193) The flowtech ones have a better chance of fitting, but may get into the framerail/torsion bar bracketry (See post 192) I don't have any 2UZ exhaust parts, so I'm not 100% on that. There are pics earlier in this thread that show what the 2UZ headers look like. I'll try you Wednesday (sorry for your loss) :(
