1uz rear main seal cover plate
AutoLuxLexES
in the desert of....
hello all,
in the middle of my r154 swap and decided to remove the rear main seal cover plate to replace the rear main seal and o-ring behind the plate, but now am wondering what should i use to seal it. it looks like there is some sort of foamy squishy grey stuff, but I am wondering if i should use the same stuff or use some oil pan FIPG to install, since I have the FIPG on hand?
what are the torque specs of the rear main seal cover bolts?
and what are the torque specs for the 3 bolts that hold the pressure plate to the flywheel?
any help is appreciated.
Thanks
Charley
ok,
well someone else gave the following torque specs for:
rear main seal plate 52in-lbs
flywheel ~75ft-lbs
pressure plate ~25ft-lbs
as for sealing rear main plate, toyota black FIPG will work
Charley
