ak47prince
- 68
- Malaysia
as you can see below.i have an ECU with 26p 16p 22p 26p ECU number is 50050. All the connectors are there except for the 4th connector that has 26p,is missing. i didn't get it from the seller and he didn't get it from his.
I followed the wiring from 'Tonyd'.. one of the members here.
1) 26p-E01 PIN 13 (GROUND)
E02 PIN 26 (GROUND)
2)16P- not shown
3)22p- IGN PIN1
STA PIN2
+B PIN12
+B1PIN13
NSW PIN 14
E2 PIN18
E1 PIN 22
4)26P- M-REL PIN4
W-CHECK ENGINE LIGHT PIN5
BATTERY PIN 26
For the 4th plug,i just hooked up the 3 pins and left the rest alone.
So... i just had a very strong crank and turn by the starter.
No spark or fuel pump running.
Do i need to feed the stop light pin with 12 volts? i tried but still nothing happen.
Any advice from you all will be much appreciated ..
Hear from you all...
Thanks..
E02 PIN 26 (GROUND)
2)16P- not shown
3)22p- IGN PIN1
STA PIN2
+B PIN12
+B1PIN13
NSW PIN 14
E2 PIN18
E1 PIN 22
4)26P- M-REL PIN4
BATTERY PIN 26
Thanks..
