1uz oil pumps and forced induction
ash
qld
hi guys,
has anyone put a 1uz alloy block , with main caps fitted, into the hot wash , parts cleaner , to see what size the main tunnel grows too ??
trying to find out the clearance on max effort turbo engine, to set up oil clearances.. Thinking around 80-100 degrees setting on the hot wash.
also, is there any upgrade oil pumps around ??
ive been sceaching, but non found .
thanks
Ash
hi guys,
thanks
Ash
go factory clearances, we went 1-thou over and lost oil pressure like crazy.
i can't speak for the UZ but i know my modular block was growing about 2-3 thou, 1-thou after just being outside in the sun not even a hot day 25c :D
upgraded pump sounds good, would like one ourselves.
yes, its a shame that a high volume pump is not made for them...
having alloy rods, and alloy block the engine will expand like crazy..and lose heaps of oil pressure.
having a tight 'cold' clearance, and lose 'hot' clearance , makes for a carefull start up proceedure
thanks for input
thanks for input
pity they aren't like a modular pump, they can be ported out a little to make them high volume ;)
yer,
if i cannot get some billet ones made, and or more volume, i'll have to take the external pump route
yer,
what sorta oil pressure are u getting? we run Brad Penn 15w40 on idle we are about 25psi when the engine temp is 200+. around 180 its 30-40psi, racing its up around 55psi.
why so much oil pressure? just remembered on the Capri its about 55psi@8000rpm we have only done close 70 passes all around 150-165mph, 4000km street driving we haven't had any issues as yet.
70 odd passes in mid to high 6 second zone , @ 200 +
i admitt its a sbc, but just sticking with what works..
im putting spray bars in rocker covers, soo there will be plenty of 'leaks' with clearances, twin turbos , spray bars, pistpn cooling etc,etc
just have to make sure we have enough slippy stuff, to stop metal to metal contact
Yep I usually fit hi vol pumps..Even when some say not too...
Oil being bled off to turbo etc doesn't help..
Tight-sh mains clearance & good oil !!!...
spare block going into hot wash this weekend...
assembled main caps..
will measure the growth from cold to hot
what fuel are u running?
i think 80psi should be enough, 110+psi seems a fair whack too high but i suppose everyone does different setups.
when the hp / cube gets over about 6...its in the hemi blown alcohol range, the proven method of oil film on the crank has to be followed
I ran a Blown SBC Methanol race engine for years and that thing had 125psi cold and around 85/90psi hot , Idle @2200rpm on 60W oil ,Never hurt a bearing in all the years I ran it , ran easy safe tune . because of the track (Townsville) still run 7.0 @ 203mph .
I can supply upgraded oil pumps if you need, just send me over a pm. The have upgraded gears and supply greater flow and pressure.
