Dean, Im still running the 3.08 ratio, but this will be swapped in the next few weeks allong with a LSD carrier. Im onto a nissan pintara diff that is the same BTR type diff as mine but has 4.11 ratio. (if any one here has a BTR 78 lsd carrier or 4.11 or 3.9 ratio gears and want to sell, drop me a line) This should wake things up a little. Some may say 4.11 is a little high but this vehicle gets little h'way use and in any case the standard ratio the crown came out with was arround 3.9. If I get print outs ect of times I will post them up. I think my 60 foot times will be very high as it bogs down off the linebut once the revs are up it takes off fairly well.
Fastj, I havent seen the flyers but I probably will be working too if it is on Sat. I still may not have my diff gears in by then, as the next time I run it I want to have the 4.11 ratio too see what sort of difference it makes.
Cheers Kris
