Hey guys 99.9% there trying to get a start on the boat but there are a few things baffling me:-
The Engine is a 91 Soarer (crashed but motor undamaged). I removed it from the car and was running upon removal.
The loom was done by Sideshow from the club...he has been a great help unfortunatley he is a bit busy to see the boat till end April but the kids are hammering me to have it finished by Easter...ho-hum woer is me....heheh
Now on the Mercruiser wiring diagram there is a switch which momentarily grounds the negative side of the coil of the carbied 350 chev.
Can anyone suggest what I can do to cut the engine revs to snick it into gear?
I was thinking of open circuiting the ground of the primary bosch fuel pump to lose pressure on the rail to drop the revs???...any other suggestions???
much appreciated, craig
- Anyway unusual situation where the battery voltage at my positive bus bar reads 12.4V.
- There are two brand new marine batteries connected via a brand new dual battery switch rated at 300A peak or 175 A continuous.
- When you try and start the engine it turns over and voltage reads 12.03V. The starter turns over quickly.
- When you try it again you get a small click from the starter and the dash goes dead and the pumps turn off. The voltage then goes to 2.5 - 3.1 volts. It then slowly builds up and after 5 mins of gradually coming up will read 12.35 V and the pumps work again as well as the dash.
- Im currently putting a charge on the batteries however as after the first attempt at start with the starter turning over OK Im thinking this is not the issue.
- I dont know if Sideshow grounds the ECU or the ignitors in his loom but I was reading this is essential. I have not checked to see if the case was ground to the engine just yet but will....and update this thread.
- Pump is a bosch 040 (the big one) for the EFI fuel rail, the other ECCO carby pump like a mini SU pump which just recirculates fuel though a small surge tank.
