1uz-fe radiator with built in oil cooler connecting
Morne van Vuuren
Hi guy's
I've just got my new radiator for a Lexus 1uz-fe vvti build into a BMW 320d.
The radiator has I'm told a built in oil cooler - can someone help advise to where these pipes connect on the engine side pls.
In the attached Pic, there are 2 copper outlets, this is what I'm looking at.
Thanks
M
The oil cooler is more than likely designed for the power steering fluid and not engine oil.
The pipe size for an engine oil cooler would be a minimum of 12mm internal diameter and power steering less, about half of that.
A photo of the inlet or outlet for the oil cooler would let us be definitive.
