spf_lexus
- 2,266
- Murrieta California
Hey is there anyway you could record some of the race? I've never seen a stripped, caged LS lapping a track. It would be pretty cool to see.
Props Spinetti. How did you place?
Right Ive got my '95 - '00 4 pot calipers, discs and pads. Then went to lexus dealer for fitting kit and anti squeal shims. £70 I nearly fainted. I also bought the lower ball joints so I dont have to hack lumps of my calipers. While I was buying stuff I also bought a set of Goodridge brake lines.
So the big changeover happens tomorrow morning. One question, do i need the dust shield (hacked down) or can I bin it?
you need to grind a small amout of the caliper where the bolt holes are
not sure I get it... 95 calipers and 95 rotors don't fit your 93? They fit my 91, but I had to change to the 95 ball joints and do an alignment.
Do you have any pictures of your set up? And what ball joint, upper, lower or do you mean tie rod end? At this point fitting these looks impossible to me unless I change the knuckle.
