88sogreatv8
- 27
So sunday last week i went to get a bite to eat. after parking sitting down eating and returning to my cressida, it wouldn't fire.
after sitting in the parking lot for 20 mins i tried to start it again and it fired so i thought my gas gauge was off and went to a gas station.
I went to the gas station and left it running , but because of the low idle it died again and this time i had to tow it home .
so the next day i started testing things . the 1st thing i found out was the fuel pump wasnt coming on when i turned the key to the run position. so i checked for fuel pressure and had nothing . I then rigged a dewalt battery to the pump circuit directly and the pump came on and i had pressure again.
so i plugged the connector back in and continued testing, the weirdest thing happened tho the key was in the run position when i unhooked then reconnected the fuel pump. the fuel pump came on with the ignition . so i shut it off and tried to restart and the pump didnt come back on. i checked the neutral safety switch fuse that i stuck in factory auto connector and the fuse was blown so i replaced it , but had the same result no fuel.
the cressida uses a main relay to trigger on the fuel pump in the run position , and that relay seems to click on when cranking the engine , but it does not come on anymore when only in the run position and not cranking.
i think im going to check all my wiring under the hood tonight , as all the wiring still looks intact under the dash , maybe ill get lucky and its just a broke connection , if anyone has had similar issue please fill free to share your story with me , it would be much appreciated
