These are tentative parts for Stage I Twin Turbo First Generation SC400 & LS400
| STAGE I | Lexus LS400 1990 - 1994 1UZ-FE |
| Parts: | 8 PSI 350 RWHP ESTIMATED |
| Quantity | Discription |
| 2 | Garrett T3 Ball Bearing for Nissan Skyline RB25 |
| 2 | Custom T3 Exhaust/Turbine housing Flange |
| 2 | Custom T3 Compressor flange 2.5" with 3 bolts |
| 2 | 2.5" 2 bolts exhuast flange and Gasket |
| 2 | T3 Flange with Gasket |
| 2 | 2" 3 bolts turbo inlet flange and Gasket |
| 1 | FM Custom Intercooler with 3" |
| 2 | Turbonectics T3 Actuators 7 psi |
| 2 | Custom Actuator Brackets |
| 1 | Tilton Oil Differential pump |
| 2 | K&N Filter |
| 1 | Greddy BOV Type S or R |
| 1 | Greddy BOV Type S Flange Adapter |
| 2 | T3 Inlet Oil Banjo bolt kit |
| 2 | Oil Drain Gasket |
| 2 | Oil Drain Outlet |
| 2 | 3/8" to 8 AN 90 degree SS elbow |
| 1 | Earl's 8 AN T fitting |
| 2 | Custom Oil Stainless steel line with teflon 4 AN |
| 5 | Custom 8 AN SS braided lines |
| 2 | 3/8" to 8 AN Adapter |
| 2 | Turbo Silicon Connector 3" (Hose Techniques) |
| 2 | Turbo Silicon Connector 3.125" (Hose Techniques) |
| 6 | 3" T-bolt clamps (Hose Techniques) |
| 2 | 3.25" T-Bolt Clamps (Hose Techniques) |
| 8 | 2" T-bolt clamps (Hose Techniques) |
| 4 | Turbo Silicon Connector 2" (Hose Techniques) |
| 1 | Vacuum Hoses (Hose Techniques) |
| 1 | MAF Adapter to 3" |
| 1 | Turbonetics 3" Cast Aluminum 90 Degrees Elbow |
| 2 | Custom Down Pipe 2.5" |
| 2 | Custom Inlet Pipes from Turbos 2" |
| 1 | Custom Intake Pipe 3" with BOV Flange |
| 1 | Dupli Color Thermal Protection |
| 1 | Misc. Wires & Ties |
| 1 | Custom 2-2" Inlet to 3" Intake |
| 1 | Cartech Rising Fuel Regulator |
