This one of the most interesting but no one ever talk about it.
There are many Lexus V8 owners want to force induce their ride,
but beside turbo or supercharger setup. You will also need
other little things to make it work. One of them would be
crankcase ventilation. In a natural aspirated engine,
there are two ventilation opening from the valve covers.
The passenger side crankcase vent into the throttle body via a
5/8" x 5" or so tube. The vent pressure is exist via the
throttle body and the crankcase pressure will vent into the
engine (red circle on the left of the picture below). The
passenger side vent doesn't have any check valve or PCV type of
valve. Its pretty much a straight connection.
On the driver side (red circle on the right of the picture below)
has a check valve called PCV (Positive Crankcase Ventilation).
What PCV really does is a check valve prevent excessive air or
pressure going into the crankcase. This is essential
especially when the engine back fire. Please see how
to Clean or Replace PCV Valve
In natural aspirated
1UZFE, the PCV is operate in mostly in negative pressure or
vacuum. It will almost never see positive pressure.
However, in forced induction application would be little
different. Without modifying the crankcase vent will lead
to disaster. The boost or positive pressure will create
excessive pressure and cause seals and oil rings to leak.
Its a bad thing. However, we need to modify the crankcase
ventilation so it will work with forced induction application.
First thing, you should change your driver
side PCV valve and its O-ring. Ages O-ring or seal will
leak pressure or cracked. I highly recommend either you
clean the pcv or replace it along with a
new O-ring. From my personal experience, the driver side
will be great if you just replace the valve and O-ring.
However, on the other side will be little tricky. I used
to just plug up the connection between the vent and the throttle
body. What I found was not letting the passenger side vent
is a bad bad thing. Here is what u need to make it work:
5-6" long 5/8" tube
1"
long 3/8" tube
1" long 1/2" tube
1 new PCV valve
Placing the 3/8" tube in
the front of the pcv valve, 1/2" tube on the rear of the pcv
valve. Now use some WD-40 inside of the 5/8" tube and
slide the whole pcv unit in the center of the 5/8" tube.
Basically you are creating another PCV system on the passenger
side. Please see diagram below.
Once the pcv unit is inside of the 5/8", now
u need to find out which direction goes where. You should
try to blow into the 5/8" tube. Make sure the check valve
venting into the throttle body. Blow into it and see if
air goes through. If it does, the the piece from your
mouth will be mounted to the valve cover vent and other side
will mate with the throttle body. Make sure you use worm
or similar lock to tighten them.
This method work the best because the passenger side can vent
crankcase pressure during idle and cruising. At the same
time, the check valve will also prevent increase crankcase
pressure when at boost. By doing this method, I noticed my
car gain little more lower end response. I can tell you
some some stories about my experience with crankcase pressure.
From years of trail and error, this is the best solution for
crankcase pressure in forced induction application.
All content in this site is copy
right by Lextreme.com. Please respect our hard work and
don't copy texts or pictures from this site. However,
links will be highly encouraged. If you feel our articles
worth while, please feel free to donate
to support our site. Thank you.
Lex.
