Lextreme: Lexus-Toyota V8 Forum
Go Back   Lextreme: Lexus-Toyota V8 Forum > V8 Performance Tech > Diagnostic & Repair Tech
Custom Search
Diagnostic & Repair Tech HELP! My car is not running right. All about Natural Aspirated OEM Lexus/Toyota V8 Powertrain. Post your N/A car problems here.
Reply
Thread Tools Display Modes
  #1
Old 09-27-2007, 11:41 PM
Bali26 Bali26 is offline
Kinder
Default LS400 High fuel consumption
Hi,
I'm a new owner of a 91 LS400 in large part due to this forum. I'm very happy with it so far. There are some things that the car needs done but I just don't have the money to have a lot done, I can barely afford gas. I prefer to buy tools than pay a mechanic. Here are my questions:
Biggest problem: The car's giving me only 13 mpg in city. Tyre preasure is maxed out 38 psi but it feels like i'm pulling a trailer. Using 91 octane. What do you think is wrong? Check engine light is ok. Can the Oxy sensors be bad and not show up in check engine? How do I find out if they are bad? I have ramps and can buy oxy sensor socket. All four may need to be replaced? Or front more important than rear? What else can i do to decrease consumption? Alternator?
Other problems:
TRAC light comes on after a couple minutes of driving and periodic humming sound. Is it ok to ignore it?
Very Minor oil leak around oil pan, PS rack area. Oil level stays high.
Very minor oil leak around PS pump, area barely moist. Oil level stays high... ok to ignore?
Sometimes car blows white smoke when started. Not always.
Upper control arm joint a little loose. little play. Ok to ignore for now?
Your advice is much appreciated
  #2
Old 09-27-2007, 11:52 PM
Lextreme's Avatar
Lextreme Lextreme is offline
Just call me "Lex"
Default
Gotta fix the PS pump before anything. Your valve seals are bad.
__________________
* 1993 SC470TT VVTi - Twin Turbo 4.7L Iron Block at work/Shine Project Body Kit
* 1995 LS520 - 5.2L Stroker with MeisterR Coil Overs and G35 19s
* 1998 GS400 - Daily Stock
* 1995 Previa - Supercharged Previa
  #3
Old 09-28-2007, 12:44 AM
Kinder
Default
Thanks Lextreme,
Since I will be doing it my self, what do you think is the best way to fix it? Buy remanufactured? Used? Repair existing? Kit?
Any advice on the fuel consumption?
Thanks a lot.
  #4
Old 09-28-2007, 04:59 AM
Deuce Deuce is offline
1st Grader
Default
Could the TRAC control be activating the brakes and causing drag? I would be de-activating it to eliminate it as a possible cause.
  #5
Old 09-28-2007, 12:59 PM
SCV8 SCV8 is offline
3rd Grader
Default
Dirty air filter perhaps...
  #6
Old 09-28-2007, 08:05 PM
Kinder
Default
Thanks,
Air filter is new. Today I checked out throttle body and it was very clean. MAP was also very clean not a spec of dust.
I put a blockage in the vac hose that goes from PS to intake manifold. Did I do good?
Should I try to replace the leaking seals in the power steering or just buy a refurbished one? Whats the best way to go for DIY?
Thanks
  #7
Old 09-29-2007, 07:58 PM
Cobber Cobber is offline
Freshman
Default
PS pump is pretty easy to fix yourself. The best way is to get a repair kit.
Don't block the hose from the ps to the manifold. Done bad.
Check the oil level in your transmission as well to make sure all is good there.
Check the cold start injector is switching off. The plug is at the top back of the inlet manifold and goes into the valley, Pull the plug off for a few days and check your economy.
http://www.lextreme.com/parts/kit.html
Oh and welcome to the forum, you won't find a better place to learn about your car and engine.
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Rod Ratio Lextreme Engine Modifications (Members Only) 3 04-16-2007 10:57 AM
1990 Lexus, transponder in the key? AmmoJammo Fuel, Ignition, Air, & Tuning (FIAT) (Members Only) 7 02-05-2007 02:17 PM
FOR SALE Crown 131 ecu and tranny ecu gsrt085 Lexus-Toyota V8 OEM & Performance Parts Classified 6 10-04-2006 11:20 PM
Manual trans adapter plate platinum0921 Lexus-Toyota V8 OEM & Performance Parts Classified 5 08-03-2006 05:47 AM
dummy lights Nick T Fuel, Ignition, Air, & Tuning (FIAT) (Members Only) 0 05-11-2004 01:21 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
