Lextreme: Lexus-Toyota V8 Forum
Go Back   Lextreme: Lexus-Toyota V8 Forum > V8 Performance Tech > Diagnostic & Repair Tech
Custom Search
Diagnostic & Repair Tech HELP! My car is not running right. All about Natural Aspirated OEM Lexus/Toyota V8 Powertrain. Post your N/A car problems here.
Reply
Thread Tools Display Modes
  #1
Old 04-23-2007, 12:54 PM
maxuslexus maxuslexus is offline
Kinder
Default Reliabilty of Lexus LS400, 1uz-fe timing belt?
Hello:
I'm a newbie here and this is my first post! I have never owned a Lexus before. However, I'm working an a "potential" deal for an 1996 Lexus LS400 with 47,000 original miles on it! This LS400 is factory original in every way! This car runs and drives great and seems to have alot of power for one of these(unmodified)LS400's! My question involves the expected reliability of the timing belt, before replacement might be needed? Please answer this question, in regards to a stock(unmodified)LS400? At this point, I just want to know just how good and reliable(Or, unreliable?)these timing belts are-since the proceedure appears to be complicated for replacing the timing belt on these LS400's? No, the timing belt on the 1996 LS400 in question, doesn't need to be changed now-but, I'm just wanting to know what the expected lifespan(In normal driving!)would be, on the average, for these LS400's? I mean, on lot's of less expensive cars-these timing belts are just "throw-away" belts and require fairly early replacement! So, are these LS400 timing belts the "throw away" type-or, are these belts of higher quality and would last much longer, for their overall life span, before "requiring replacement? Please explain and clarify your answers? Thank you!
  #2
Old 04-23-2007, 12:59 PM
Lextreme's Avatar
Lextreme Lextreme is offline
Just call me "Lex"
Default
47K is very low. I just got a 1995 LS400 with 141K and its very smooth and quiet. As for the life of the timing belt, they are good for 95 to 100k miles. So you are good for the next few years.
__________________
* 1993 SC470TT VVTi - Twin Turbo 4.7L Iron Block at work/Shine Project Body Kit
* 1995 LS520 - 5.2L Stroker with MeisterR Coil Overs and G35 19s
* 1998 GS400 - Daily Stock
* 1995 Previa - Supercharged Previa
  #3
Old 05-15-2007, 08:19 AM
miamistyle miamistyle is offline
Kinder
Default
On the TB, Lexus says 90k or 6 years. You don't want it to go on your 96, it's got the interferance engine. If it snaps you'll need a lot more than another belt. At the least I would have it inspected.
  #4
Old 05-15-2007, 11:33 AM
stevechumo's Avatar
stevechumo stevechumo is offline
Master
Default
Quote:
If the timing belt breaks on the LS, it shouldn't snap anything else such as the head valves..etc. Toyota designed this better than a Honda. However, a Toyota/Lexus with a broken belt should need to be stopped immediately to prevent further damage.
David is right. The LS/SC belt is way too good at around 90K miles. It's recommended to be replaced at this point by factory. However, to be sure take out the belt cover, turn the crank slowly and check for any wear or crack.
__________________
Single Turbo SC400 15 psi (389 rwhp and +400 rwtq), AEM EMS, Lextreme Hi-Performance Torque Converter, Hi-Performance Built Tranny with Shift Kit, Tein SS Coilover, Supra LCA, Big Brakes, Stainless Steel Brake Lines, LSD, Strut Bar, And Many More.
  #5
Old 05-15-2007, 12:03 PM
Lextreme's Avatar
Just call me "Lex"
Default
I think 1995 and up are interferance engines. So, if the dealer require change of TB every 6 years, then I think you should.
__________________
  #6
Old 05-18-2007, 05:00 PM
Thermactor's Avatar
Thermactor Thermactor is offline
5th Grader
Default
My '96 is on its second timing belt - last time it was done was at 120k, now it's at 243k... I must be on borrowed time? When I took the spark plug valley covers off, the timing belt looked fine to me.
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
91 lexus ls400 timing belt question jx295c Diagnostic & Repair Tech 12 01-24-2008 09:28 PM
FS: OEM Timing belt kit 1uz 90-97 WDoherty Lexus-Toyota V8 OEM & Performance Parts Classified 0 01-08-2008 09:38 PM
1UZ timing belt... compatible accross UZ series?? ed_ma61 Engine Modifications (Members Only) 3 01-12-2007 05:00 AM
HEEELP Timing Belt 1UZ-FE VVT-I igor99 Diagnostic & Repair Tech 1 02-24-2006 03:06 PM
Timing Belt Unique General Discussion 2 10-06-2005 06:54 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
