Lextreme: Lexus-Toyota V8 Forum
Go Back   Lextreme: Lexus-Toyota V8 Forum > V8 Performance Tech > Diagnostic & Repair Tech
Custom Search
Diagnostic & Repair Tech HELP! My car is not running right. All about Natural Aspirated OEM Lexus/Toyota V8 Powertrain. Post your N/A car problems here.
Reply
Thread Tools Display Modes
  #1
Old 02-28-2005, 05:27 PM
tracyb tracyb is offline
Kinder
Default how hard is the head gasket?
My ls400 started having problem so it was taken to the shop, the people at the shop who i completely trust say that the head gasket is gone and that the pistons may have also been damaged. so here is the question. can i change the head gasket myself?... the reason i ask is because i cant find any wright-ups and dont yet have a manual to see what the process involves. my background in engine work is limited to jeeps. i have done everything to a jeep except for digging lower in the engine than the head, so i would say that is my weak spot. so far things like engine tranny t-case swaps and allsorts of suspension setups haven't be too hard. but i know that this is jeep, its simple. this is why i am hesitant to try the rip apart the lex, i dont think there nearly as simple as the jeep (if this were a jeep it would already be in piece's) so do you think this task is too big for me, i'm mostly worried about small things that might make this too hard for me. any segestions would be great manual segestions and web wright-ups would be greatly appreciated-sp?
sorry for the long post
-bart
  #2
Old 02-28-2005, 05:45 PM
Peewee's Avatar
Peewee Peewee is offline
Moderator
Default
Unless you have extremely mistreated the motor, I can't see a head gasket going.
Also, if the pistons have been damaged, its motor out time.
And for the cost of an import motor these days, just buy another one.
But find out what is wrong with it.. Why does he think the head gasket is gone?
__________________
Peewee
  #3
Old 02-28-2005, 07:36 PM
Kinder
Default
thats what i thought too. the motor only has 135,000 miles on it and from what i've read this doesn't sound the least bit typical of this engine. i'll give the mechanic a call tommorow and get the specifics on the reasoning.
-thanks for the reply
  #4
Old 02-28-2005, 08:05 PM
Lextreme's Avatar
Lextreme Lextreme is offline
Just call me "Lex"
Default
Test the fluids. Oil and radiator water. If they look normal then your gaskets should be ok.
__________________
* 1995 SC470TT VVTi - Twin Turbo 4.7L Iron Block at work
* 1995 LS520 - 5.2L Stroker with MeisterR Coil Overs and G35 19s
* 1995 Previa - Supercharged Previa
  #5
Old 03-01-2005, 09:01 PM
Kinder
Default
alright so i kinda got the report on what was wrong unfortunately i'm at college and the car is in my home town so i have to hear this from the mechanic to my brother (who doesn't understand cars) then to me. so here it is-
the feeling from the car it was overheating and had a noticible loss of power, then it went to the shop. at the shop they found water is two of the cylinders but the appearently said nothing about oil in the coolent or coolent in the oil. they wouldn't give a print out of a estimate because the wern't sure enough that the head gasket was the only problem bu they did say the min would be about 3500 in repairs and sugested a junkyard engine. i was dissappointed that this is all the info i have for now. so i think this pretty much means to me new engine. but if you can give any more info, maybe a good place to get engines (i'll be searching car-part.com) the advice would be much appreciated.
thanks, bart
  #6
Old 03-01-2005, 09:06 PM
Lextreme's Avatar
Just call me "Lex"
Default
If it is gaskets problem. Its cheaper to get used engine than fixing it.
__________________
  #7
Peewee's Avatar
Moderator
Default
In the event that there was water in a cylinder, the car would have been blowing tremendoes white clouds out the rear.
Was this the case?
Either way, if the heads have to come off, dont do it.
Not at $3500ish.
Get a *** import motor for under $1000, have that installed, and sell the other motor to someone on here for cheap.
At least, that is what I would do in the same situation
__________________
Peewee
  #8
Old 03-01-2005, 09:36 PM
Kinder
Default
thanks for the help- it will be gettin a new engine.
-bart
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
n00b head gasket - head studs and boost Q -Nemesis- Forced Induction Tech (Members Only) 11 09-04-2008 10:56 PM
Head gasket set question? 4000GT General Discussion 7 01-05-2008 07:49 PM
Making a Copper head gasket vn1uz Engine Modifications (Members Only) 21 09-13-2007 11:14 AM
Blown Head Gasket Lextreme Forced Induction Tech (Members Only) 4 09-06-2006 05:39 PM
Copper Gasket and Head studs Lextreme Engine Modifications (Members Only) 30 01-07-2004 11:36 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
