| General Discussion Newbies and Introduction. Its time to brag about yourself. This section is also for general discussion that is not cover in any other sections. Anything goes. |
Thread Tools | Display Modes |
#1
1999 Toyota Altezza
Engine - Toyota 1UZFE 4.0L V8 quad cam 24-valve, stroked crank (4.5L), Eagle rods, JE pistons, Total Seal rings, oversized Manley valves, custom valve springs, custom steel cams, ported heads, 8 x 4AGE throttle bodies, 440cc injectors, 4x fuel pumps, twin Motec CDI ignition computers, twin 2" stainless exhausts, aluminium radiator, alloy oil cooler, Motec M8, dry sump. Driveline - Richmond 5 speed road/race box with short shift, DVM chromoly flywheel, AP 3 plate racing clutch, AP slave cylinder, Supra LSD and axles, Skyline driveshaft. Suspension - Proflex shocks with remote resrvoirs, Eibach coils Brakes - Front - AP Racing 6 pot calipers with Pagid pads, 356mm rotors, braided lines, floor-mounted pedal box, Rear - Altezza calipers with Pagid pads. Wheels/Tyres - Weds Racing 18x9", Dunlop type R race slicks. Exterior - Aftermarket body kit consisting of front spoiler, rear bumper, side skirts, flared guards, in-cabin adjustable knife blades, fibreglass bonnet, carbon fibre wing. Interior - Racetech 4009 FIA seats, Willans five-point harnesses, Motec stack dash, Momo steering wheel and knob, military spec wiring, chromemoly rollcage, Terratrip meters. Performance - 500+bhp@ 8500rpm As featured in NZ Performance Car, Nov 2004. The car was built to compete in the TargaNZ, circut racing, and possibly the Bathurst 24 HR. It is road registered!!!!!!! |
#2
look awesome, is there a write up somewhere? and does eagle make rods for the v8 or were they adpted to fit the stroker setup?
#3
What happened to the other 8 valves?
#4
Quote:
I posted up about this quite a while ago and believe that the owner (or builder not 100% sure) was a member on these forums Logan
__________________
AKA 92GTApex www.toyspeed.org.nz www.toyperformance.org.nz www.area-51.co.nz Current rides:92 Toyota Levin GT Apex 20valve Projects:2x Toyota Levin GT Apex 20valve (Crashed=It wasnt me) MA70 mark3 Supra |
#5
Hi Guys
This is Boothys car. Seen it many times. Often gets suspension work done around the corner and tuned at another shop in Hamilton. Nice job. |
#6
is there any where i can get the article about it? --it be nice to see the pics...
#7
Sounds expensive....
__________________
![]() * 1993 SC470TT VVTi - Twin Turbo 4.7L Iron Block at work/Shine Project Body Kit * 1995 LS520 - 5.2L Stroker with MeisterR Coil Overs and G35 19s * 1998 GS400 - Daily Stock * 1995 Previa - Supercharged Previa |
#8
a picture is worth a thousand words or something like that.
__________________
Total Toyota bliss. |
#9
Hopefully I will be able to attach some photos of the V8 Altezza. It was at a motor show. Cheers
#10
Very nice and very clean.
__________________
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| How's it goin? | no_frills | General Discussion | 0 | 07-13-2009 04:28 AM |
| SC400 (1uz-fe) stock HP capacity work sheet.... | jibbby | General Discussion | 18 | 02-10-2008 08:08 AM |
| Looking for a 1993 SC400 ECU cheat sheet | cowboy bebop | General Discussion | 5 | 05-02-2006 07:20 PM |
| 92 Aus spec 4runner | gus75 | Swap, Conversion, Transplant, Specialty Vehicles & Project Diary (Members Only) | 12 | 10-25-2005 10:19 PM |
| US Spec 1UZFE Injector | Lextreme | Fuel, Ignition, Air, & Tuning (FIAT) (Members Only) | 6 | 02-07-2005 12:41 AM |
