Lextreme: Lexus-Toyota V8 Forum
Go Back   Lextreme: Lexus-Toyota V8 Forum > V8 Performance Tech > Forced Induction Tech (Members Only)
Custom Search
Forced Induction Tech (Members Only) Supercharged, Turbocharged, NOS, Intercooler, Methanol Injection & Go Fast and None OEM Stuffs.
Reply
Thread Tools Display Modes
  #1
Old 11-04-2013, 07:31 PM
birdduck birdduck is offline
Kinder
Default supercharger or turbo?
okay looking for opinions and suggestions for my next project..
looking to ad FI to my 1uzfe swapped 4runner.
basic low down=
engine:90 ls400(all emissions stripped) all stock otherwise
drivetrain: R150(factory v6 runner drivetrain)
fuel supply: factory 90 v6 runner.
my end goal is just to have a well functioning FI system
i know it will add power but this is simply to be a factor for the ride..
i will be happy with gains of around 50-70hp, this is a daily driver, so not looking to make a monster, it kinda already is ...
so i have some choices, supercharger? or remote mount turbo?
all fab/plumbing/welding ect... will be done by me, and i am more than capable of doing said tasks (saves a boat load of cash) i am more so trying to decide what will best suit my desires?
looking for easy to drive without building boost putting around, but there when i want it(i like lag)
i have almost every component to do either one(i don't currently have a turbo, looking at a hx35-40) i do have access to a eaton charger but not sure what size it is(bigger than m90).
would like to keep the fuel system as stock as possible(i can upgrade injectors if i need more fuel) stock ecm/ignition ect..
whats your take?
  #2
Old 11-05-2013, 02:36 AM
cribbj's Avatar
cribbj cribbj is offline
"Supra" Moderator
Default
Superchargers are much easier to install from a plumbing perspective, as you're only dealing with the intake side of the engine, whereas with a turbo, you're having to fabricate new intake AND exhaust plumbing.
You do have to come up with a belt drive for the supercharger, but that's not difficult and has been done many times before.
Superchargers will give you boost NOW and from whatever RPM you want. So they'll help your torque curve quite a bit. Turbo's help your HP curve from midrange up to the top.
Superchargers "steal" power from your crankshaft; sometimes up to 50-60 HP in extreme cases of high boost, while turbos don't, so turbos will win the HP/boost contest.
__________________
High mileage, low compression, and sometimes not firing on all cylinders, just like my cars.....
New Daily Driver (Ferrari 550 Maranello)
Supercharged Supra Project
BMW V12 Project
2JZ-GZTE Project
  #3
Old 11-05-2013, 07:06 PM
Kinder
Default
i do want to ability to drive without boost, the supercharger i have access to is rather large and will be pushing a lot of cfm. i do like the idea of not having to risk clearance like i would with the remote mount..
i am pretty sure i can keep it at least level with the frame rails but you're right about all the plumbing, its going to be a rats nest under there.. oil lines, charge pipe... but its still an option for me simply for the boost on demand concept of a laggy turbo.
  #4
Old 11-05-2013, 07:43 PM
Kinder
Default
okay i actual y have access to two superchargers... mp112 and an m90
  #5
Old 11-05-2013, 10:37 PM
BlackUZZ31 BlackUZZ31 is offline
4th Grader
Default
I have a 112, it's nice... 3.3" pulley gives 7psi, 2.6" 12-14psi
this is 7psi:
  #6
Old 11-06-2013, 07:35 PM
Kinder
Default
keep forgetting about the conversion.. i saw the number and thought 215hp to the wheels?
that's not much.. ooo kw...
Reply
Tags
1uzfe, 4runner, supercharger, turbo
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
