Lextreme: Lexus-Toyota V8 Forum
Go Back   Lextreme: Lexus-Toyota V8 Forum > V8 Performance Tech > Swap, Conversion, Transplant, Specialty Vehicles & Project Diary (Members Only) > Wiring
Custom Search
Wiring This area is specificallly for trouble in wiring and wiring related topics.
Reply
Thread Tools Display Modes
  #1
Old 08-14-2012, 01:13 AM
Sam16v Sam16v is offline
Kinder
Default 1994 Lexus Ls400 Wiring Diagrams
Hi folks new to the site and currently undertaking a 1uz Swap into a Mk4 Toyota Hilux.
The donor vehicle is a 1994 Uk spec Ls400, and despite some serious searching and im struggling to find the correct ECU wiring diagrams. The 1996 LS400 diagram does look very similar apart from wire colours? can anyone confirm this?
If not does anybody have a copy of a wiring diagram that they could share? Many thanks
  #2
Old 08-14-2012, 03:32 AM
Bushwhacker's Avatar
Bushwhacker Bushwhacker is online now
3rd Grader
Default
Go by the pin numbers not the colours. The pins will be the same as the '96 diagram.
  #3
Old 08-14-2012, 03:58 AM
Kinder
Default
Great stuff cheers for that, was worried there may be more differences than just the colours.
  #4
Old 08-15-2012, 04:19 AM
samsdad's Avatar
samsdad samsdad is offline
5th Grader
Default
Just to be sure check the chassis/model code of the donor (if you don't have that then search the part no off of the ECU on toyodiy) if it's a UCF20 then yes the pin numbers should be the same but some UCF10 models had the same type of plug configuration and the pins are different. I think that MY (model year) 93 was the model change from UCF10 to 20 (meaning 1994 car) and MY96 was the change to VVTi. For some reason Toyota (Lexus) do seem to make changes to wiring colours from year to year, however this may also be influenced by who the supplier was for the looms for various production runs.. Either Denso or Yazaki
__________________
1990 Toyota Hilux Surf SSR-G 1UZ-FE V8 5 Speed manual ( Motor ex UZZ31)
1992 Toyota Hilux Surf 2 door "Wide body" Auto. The Wifes drive.
1982 RN41 Hiliux.. UZ is Coming (it's like Christmas)
1973 Toyota "Peanut". No she is not getting a 1UZ. 3K-B and 5 speed thank you
  #5
Old 08-27-2012, 08:39 AM
Kinder
Default
Ok cheers for that, engine side of things is all wired just onto the autobox now. and seems there are few deifferences. Had a search on ToyoDiy and its a UCF10 (89-94 spec ecu) does anyone have a copy of the wiring diagram to suit, that they would be willing to share? thanks again
  #6
Old 08-27-2012, 01:08 PM
gloverman gloverman is offline
Senior
Default
check engine specs and diagrams at the bottom of this page.
  #7
Old 08-27-2012, 02:08 PM
3rd Grader
Default
Quote:
There's nothing to wire up on the auto transmission, it's all in the ECU plugs.
(Assuming you're using the Lexus transmission that came with the V8 of course)
  #8
Old 08-27-2012, 06:31 PM
Senior
Default
I disagree. They need the selector switches , stop switch, kick down, Neutral start etc wired. Cheers
  #9
Old 08-28-2012, 12:56 AM
cruising cruising is offline
Kinder
Default
which wires i will cut out bushwaker?
leave just auto 6 wires on black plug back gearbox
cut rest out i will?
  #10
Old 08-28-2012, 07:33 AM
Kinder
Default
Thanks again for the replies, Yes Im using the Lexus autobox, Realise that some of the Autobox wiring is intergrated with the ecu plugs but, have to agree with Gloverman, surely all the switches need to be connected to the ecu so that the autobox will function correctly?
just need a pinout, as the 96 diagram seems to differ from the 94 one iam looking at? cheers
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
