Lextreme: Lexus-Toyota V8 Forum
Go Back   Lextreme: Lexus-Toyota V8 Forum > V8 Performance Tech > Fuel, Ignition, Air, & Tuning (FIAT) (Members Only)
Custom Search
Fuel, Ignition, Air, & Tuning (FIAT) (Members Only) Stand Alone ECU, Piggy Back ECU, Wiring, Tuning, Injector Upgrades, Air Fuel ratio, Fuel Pump, Ignition, FMU, FPR and any engine electrical/fuel component relative topics.
Reply
Thread Tools Display Modes
  #1
Old 09-01-2004, 09:22 PM
uzz32pete uzz32pete is offline
1st Grader
Default Unichip on V8 Soarer done.
Very pleased with the results. 6 degrees timing added, AFR from 10.8 to 12.8. Car is performing very well.
  #2
Old 09-01-2004, 11:12 PM
Lextreme's Avatar
Lextreme Lextreme is offline
Just call me "Lex"
Default
Peter,
Is that FI or NA dyno?
__________________
* 1993 SC470TT VVTi - Twin Turbo 4.7L Iron Block at work/Shine Project Body Kit
* 1995 LS520 - 5.2L Stroker with MeisterR Coil Overs and G35 19s
* 1998 GS400 - Daily Stock
* 1995 Previa - Supercharged Previa
  #3
Old 09-02-2004, 02:05 AM
Shuey Shuey is offline
2nd Grader
Default
Any other mods to your set up, ie extractors etc... What was your base line engine configerations?
What was the Uni Chip set up worth to buy and tune? I'm keen to look at those sort of gains for my Hilux...
Cheers,
Shuey
__________________
Modified Madness!!!
  #4
Old 09-02-2004, 06:00 AM
1st Grader
Default
na dyno,
headers and intake are main mods.
$1300 Aud install and tune.
well worth it for me.
It's the only way I could find to have my car tuned for fuel and timing on a dyno and on the road with engine microphones. I wanted it professionally tuned
  #5
Old 09-02-2004, 06:01 AM
1st Grader
Default
And I can get the car retuned later for bigger injectors and supercharger.
  #6
Old 09-02-2004, 11:58 AM
JBrady JBrady is offline
Moderator
Default
Excellent results!!!
looks like you picked up nearly 21rwhp and 30rwtq... to 212rwhp and 266rwtq... very nice.
One thing is strange about the dyno sheet is that it gives vehicle road speed but not RPMs... RPM would be nice info.
__________________
1999 LS400
Best ET: 14.22 @ 99.38
  #7
Old 10-31-2004, 08:23 AM
highlander highlander is offline
Kinder
Default
I was wondering... can that unichip be custom modified here???
The climate is really tough on cars here... any more info on that unichip?
__________________
LS400 95 being restored to new conditions. Help always appreciated.
Damaged power lock actuators
Damaged Nakamichi Amplifier
Completely Worn Out Suspension
  #8
Old 10-31-2004, 03:47 PM
Lextreme's Avatar
Just call me "Lex"
Default
Yes the unichip can be custom and modified. However you would need a Unchip Tech to do that for you. Contact them....
__________________
  #9
Old 11-01-2004, 05:30 AM
1st Grader
Default
Dyno dynamics(common in Aust) machines read on average 12% lower than a Dynojet machine common in USA. I have read this several places including one workshop with both machines installed.
So that works out to be 233 rwhp in Dynojet terms. My car is also pushing a whopping big suspension oil pump - it's part of the Active suspension not found in USA cars. I don't know how much power this saps. When the suspension pump belt is off the car feels much stronger.
In Australia a stock UZZ32 runs about 120 rwkW - not very much. Mine also ran this figure before mods began.
  #10
Old 11-02-2004, 04:12 PM
SCV8 SCV8 is offline
3rd Grader
Default
Tha feature i enjoy the most(besides the extra power), is the absence of the "learning ecu" that retards the timing if you don't floor it every time you drive the car!
Did your Japanese market car have such a setup as well?
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Soarer Unichip SilverLux Piggyback ECU 2 08-05-2009 01:21 PM
Motec vs Autotronice vs unichip thalj Fuel, Ignition, Air, & Tuning (FIAT) (Members Only) 2 08-28-2007 10:56 PM
Unichip?? flyboi001 Piggyback ECU 2 05-25-2006 11:20 AM
Unichip Info Gazzasore Fuel, Ignition, Air, & Tuning (FIAT) (Members Only) 4 02-14-2005 06:49 PM
Unichip ECU for 1995 sc400 WUKWS Fuel, Ignition, Air, & Tuning (FIAT) (Members Only) 0 01-11-2005 02:21 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
