| Fuel, Ignition, Air, & Tuning (FIAT) (Members Only) Stand Alone ECU, Piggy Back ECU, Wiring, Tuning, Injector Upgrades, Air Fuel ratio, Fuel Pump, Ignition, FMU, FPR and any engine electrical/fuel component relative topics. |
Thread Tools | Display Modes |
#21
very helpful stuff mate thanks. i think the xtreme is the way im leaning, just for future scope?
do you have any idea what size supercharger pulley i should go for, its currently running a 6psi pulley im unsure of what size that actually is? currently running around 400hp at this pressure, if im going to spend the money on standalone and mapping, then i would like at least another 100hp ? any ideas on pulley size, and also i suppose i may have to upgrade to 8pk or 10pk pulleys and belts to stop the belt slipping. |
#22
Flick me an email info@thecartunecompany.co.nz and I can see what sort of price I can do on an Xtreme for you. I have been working with CribbJ on options for running an Xtreme on his supercharged beast. We have a local engineer that makes up gilmour drives for us when we start having slipping problems on superchargers. Cheers Kelvin
#23
thanks for the positive response! i was just suggesting an option based upon the original post where no information about his goals were given.
#24
Quote:
__________________
Single Turbo SC400 15 psi (389 rwhp and +400 rwtq), AEM EMS, Lextreme Hi-Performance Torque Converter, Hi-Performance Built Tranny with Shift Kit, Tein SS Coilover, Supra LCA, Big Brakes, Stainless Steel Brake Lines, LSD, Strut Bar, And Many More. |
#25
will most likely be a soarer
#26
You mean the Lexus SC400? So it's currently not on the Soarer/SC400?
__________________
#27
its currently in a mk3 supra, but i am possibly purchasing the supercharger kit to fit to an sc400/soarer yes.
#28
I see.
Regardless of the cost, there're actually both advantages and disadvantages of the standalone ecu. Advantages: wide range of controlling/tuning the engine and auto tranny. Due to the complete controlling of the engine and tranny, the max hp can be achieved. Disadvantages: Not too many tuners know how to tune the auto tranny. A crappy tune of the auto tranny will give a sluggish or tiredsome driving. Manual tranny is no worry. Another thing is controlling electronic accessories. A standalone may not be compatible with those. On the other hand, a good/hi-end piggyback ecu can be used to tune engine/boost/timing while it still retains accessories and the way the auto tranny was set up from stock. Basically, the OEM ecu is kept to control the accessories and the auto tranny, while the piggyback ecu controls the engine/boost/timing. Some piggybacks have similar options like standalone ecus. I had been looking into AEM FI/C piggyback before deciding to go with the standalone AEM. I read and it's pretty good. It's not because the standalone is better. It's because I had a good deal on the standalone. In fact, the AEM FI/C and the wiring costs the same as the AEM standalone.
__________________
#29
forget bout trans ecus
once u need to do that then u might as well have open cheque book and u might open a can of worms just get an ok ecu and just piggy back it to just run injecotrs and 2 coils because of the auto its no use going to far with it so keep it basic run a piggy back ecu leave orig ecu to run air con and idle etc etc would be cheapest way out of it |
#30
it wont be auto! no thanks, this will be a drift car with either w58 or r154 manual gearbox
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
