Lextreme: Lexus-Toyota V8 Forum
Go Back   Lextreme: Lexus-Toyota V8 Forum > V8 Performance Tech > Engine Modifications (Members Only)
Custom Search
Engine Modifications (Members Only) Performance Pistons, Rods, Cams, Heads, Gaskets, Head Studs, Compression Issues, Valves and Springs.
Reply
Thread Tools Display Modes
  #1
Old 08-31-2011, 09:52 AM
BigSteve BigSteve is offline
Kinder
Default Camshaft timing
Does anyone know how many degrees of timing each tooth on the Intake cam timing gear, and scissor gear are?
I saw somewhere mention of it being 7.5 degrees, so was wondering if it were possible to retard the intake cam 7.5 via shifting the gear 1 tooth and advance the exhaust 7.5 via the scissor gear to tighten the overlap (or other way around) to shift the power band up and down.
Next important question, does anyone know the factory piston to valve clearance at TDC?
Cheers.
  #2
Old 08-31-2011, 01:54 PM
gloverman gloverman is offline
Senior
Default
I beleive it is possible to get adjustable sissor gears along with adjustable cam gears. This would make it easier to get good gains. Cheers
  #3
Old 08-31-2011, 03:18 PM
Kinder
Default
Ah that'd be nice, for adjustable cam gear you need to lose the rotors/caps I think.
I have not seen any available, I'll keep looking around.
Even if this were possible I think 15 degrees total might be pushing it.
  #4
Old 08-31-2011, 03:24 PM
ash ash is offline
3rd Grader
Default
Cheers.
count the number of teeth on the pulley, and divide by 360
that gives a ball park on whateach tooth will adjust cam timing by..
i should be looking at PV clearance this weekend.
i ordered some weak springs to play with this
  #5
Old 09-01-2011, 02:09 PM
Kinder
Default
Cant find adjustable cam gears anywhere, I spoke to kelford and they said they were trying to get some made but never managed to.
  #6
Old 09-01-2011, 05:48 PM
Senior
Default
I just talked to one of my suppliers who makes them up. Hopefully he will find some time in his busy schedule to send me some photos soon.
  #7
Old 09-03-2011, 04:42 AM
samsdad's Avatar
samsdad samsdad is offline
5th Grader
Default
Steve there's a good reason for this and it is coz quite simply there isn't the room in the heads to fit adjustable cam gears where they'd hold together and remain adjustable (or hold together for that matter hence why nobody has done it yet, plus without the scissor gear they'd rattle like hell which is why you bought it in in the first place). Were each cam driven by the timing belt then this wouldn't be an issue. Also in the course of reassembling everything going a tooth either side on the scissor gears is not an option. Without the high lift cams the 1U isn't "interference" but with it is so that's the difference of almost 1mm lift. You'll be happy with the results but. Aint driven it yet but it sounds totally evil
__________________
1990 Toyota Hilux Surf SSR-G 1UZ-FE V8 5 Speed manual ( Motor ex UZZ31)
1992 Toyota Hilux Surf 2 door "Wide body" Auto. The Wifes drive.
1982 RN41 Hiliux.. UZ is Coming (it's like Christmas)
1973 Toyota "Peanut". No she is not getting a 1UZ. 3K-B and 5 speed thank you
  #8
Old 09-03-2011, 04:52 AM
XR8tt's Avatar
XR8tt XR8tt is offline
Moderator
Default
Keep in mind the cams spin 1/2 crank speed when working out cam timing...
__________________
When capacity isn't enough?
Forced induction....
  #9
Old 09-03-2011, 04:15 PM
Kinder
Default
Yeah I can work out the timing XR8, was just wondering if it were possible. Wasn't sure on the valve to piston clearances etc but samsdad cleared that up.
I guess best option is just to match the other mods to the power range of the cams rather than adjust the cam seperation.
Looking forward to hearing her up and running!
  #10
Old 09-04-2011, 04:57 PM
Kinder
Default
Just heard from Kevin (kelfords) this morning via email, He mentioned they've bought the gear they needed to make the adjustable gears so they're going to get started on that soon.
Bit of good news there for those looking for adjustable cam gears.
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
