Lextreme: Lexus-Toyota V8 Forum
Go Back   Lextreme: Lexus-Toyota V8 Forum > V8 Performance Tech > Drivetrain (Members Only)
Custom Search
Drivetrain (Members Only) Transmission, Manual Conversion, Tiptronic, Rear-End, Torque Converter, Gear Ratio, Rack & Pinion, Brushings, LSD & Axle. Anything behind the engine.
Reply
Thread Tools Display Modes
  #1
Old 06-26-2011, 01:58 PM
gloverman gloverman is offline
Senior
Default Surf/lexus auto oil supply
Now I have seen plenty of write ups on how to fit a Surf Transfer box(130 series electronic 4x4 engagement) onto a lexus auto. Non these boxes share housings just like supra and many other vehicles fitted with this series of aisan gearbox. Even the asian warner box fitted to other models looks very similar. Now my question is how long are these setups lasting. Specifically the rear bearing in the transfer adaptor housing as the oil feeds to this bearing and the rear housing bearing in the lexus box are very different. Non of the write ups have shown any mods to the oil system. Now its possible that there is enough oil splashed around the box to lubricate the transfer housing bearing. This is one problem with forums, lots of info often lacking the finer details and very few followups on lifespan and faulures. Ill show some photos to explain.
  #2
Old 06-26-2011, 02:11 PM
Senior
Default Heres my test box
This is my test box we use for checking positions of componants and for explaining to customers what we are wanting to acheive. You will notice it is the lightweight model. Nothing inside the trans as it is one of the spare bodies I have which has been stripped out. Transfer is a good one so its a little tail heavy.
First picture shows it going together
Second picture - nothing inside the trans
Third picture - I had to clean it - looks much better
  #3
Old 06-26-2011, 02:26 PM
Senior
Default oil feeds - lexus auto
Now the oil feed I am refering to is shown here. The lexus box the oil is supplied to the tailshaft bearing via the hole shown in photo 1. The speed sensor trigger wheel is clamped tightly onto the front bearing surface (photo2) allowing oil to travel inside the speed sensor sleeve through the bearing centre and onto the outside of the bearing where it drains through a small slot in the outter bearing face (photo 3) and then drains back through the rollers of the bearing and back into the gearbox sump. Notice in photo two there is the drain hole for the oil on the front of the bearing and it creates small dam of oil at the bottom of the bearing.
  #4
Old 06-26-2011, 02:37 PM
Senior
Default Surf auto
Now the surf oil feed to the transfer adaptor is straight out end of the little stubby tailshaft (photo 1) through a little hole in the end plug(photo2). From here it goes into the front of the transfer box input shaft and out through a small hole in the side of this shaft(photo 3), then it drains back through the rollers of the bearing with the same dam setup as the lexus auto. The dam is on the opposite side of the bearing but that makes no difference.
  #5
Old 06-26-2011, 02:41 PM
Senior
Default The big question
Now back to my question. To the guys that have simply cut the lexus tail shaft , drilled the speed sensor hole and shorted and reattached the lexus speed sensor and done nothing about the oil feed to the rear bearing. How long have they been lasting? Is anyone brave enough to say they have had a failure? How many kms have people done on these boxes? There is a chance that that rear bearing gets some lubrication through splash feeding as we all know sometimes things that shouldn't work do infact work.
  #6
Old 06-27-2011, 03:15 AM
jen3ss's Avatar
jen3ss jen3ss is offline
1st Grader
Default
I'm interested in this one as well, I have never heard of one failing.
  #7
Old 06-28-2011, 11:08 PM
duza's Avatar
duza duza is offline
2nd Grader
Default
Mines been in my Hilux for just under 3 years and it's done around 60000ks. Much of this is around Sydney metro, but for the last 3 months I've travelled to Canberra and return every Sunday, aprrox 3hrs each way. So far, no worries.'
Ric
  #8
Old 07-13-2012, 03:39 AM
pinkytamz pinkytamz is offline
Kinder
Default
here is what i did as i thought there would be a prob with the rear bearing (first thought was to replace with a sealed bearing ( but as i have been working in a hyd work shop i got to thinking about oil flow hot and cold ( my main reasons for finding a fix for this was as i had planned to buy a proper adaptor to fix this but got put off by the freight bill . so what i did was to fit a 1mm restrictor tee to the oil pump / oil cooler tube and then drill a new oil feed through to the rear bearing to give it its own low pressure oil feed ...i have not finished my engine yet but i have tested the the trans oil pressure and flow to the rear bearing using our hyd test rig and there is shit loads of flow to the oil cooler and the rear bearing so this is how i did mine so i cant see any probs with this working on or off road
  #9
Old 07-18-2012, 03:55 AM
samsdad's Avatar
samsdad samsdad is offline
5th Grader
Default
Not had any issues with any so far but the last one I put the Surf mainshaft into the autos as the client wanted the boxes overhauled before use as it had been sitting unused for a period of time and condition was unknown. Those with the trimmed mainshaft still seem to "splash feed" fine but a very good point to bring up. The main issue that has come in is people filling them with the wrong fluid and thus premature failure, but this applies to the stock Surf auto as well
__________________
1990 Toyota Hilux Surf SSR-G 1UZ-FE V8 5 Speed manual ( Motor ex UZZ31)
1992 Toyota Hilux Surf 2 door "Wide body" Auto. The Wifes drive.
1982 RN41 Hiliux.. UZ is Coming (it's like Christmas)
1973 Toyota "Peanut". No she is not getting a 1UZ. 3K-B and 5 speed thank you
  #10
Old 04-25-2013, 02:31 AM
Kinder
Default
WELL on the second 1uzfe to surf job now and thought i would update kelvins question about the ( maybe) oil flow fault to the rear bearing ... if you use the lexus auto and cut the output shaft down to about 64mm when you refit the speed sensor onto the output shaft use a grub screw to hold it in place but make sure this grub screw blockes the oil feed hole on the shaft . then you re-drill the hole through the end of the shaft in the same place as the surf auto . if its been cut to the correct length you only drill into the shaft about 10mm to pick up the oil feed. but you will need to know how to sharpen drill bits as it is hard but not impossible
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
