Lextreme: Lexus-Toyota V8 Forum
Go Back   Lextreme: Lexus-Toyota V8 Forum > V8 Performance Tech > Engine Modifications (Members Only)
Custom Search
Engine Modifications (Members Only) Performance Pistons, Rods, Cams, Heads, Gaskets, Head Studs, Compression Issues, Valves and Springs.
Reply
Thread Tools Display Modes
  #11
Old 04-22-2011, 02:37 PM
spf_lexus's Avatar
spf_lexus spf_lexus is offline
Bachelor
Default
Quote:
ok so i keep reading that the lower intake manifold is a real problem area on these engines, why is that and is there a known fix for it?
use the forum and search for Justin_gt8, and he can give u the exact details on how to. The lower manifold chokes off power at 5500-6000rpm and when its replaced with a short runner manifold, it extends the power band to 6000-6500rpm before choking off with no loss in low end hp/tq.
Toyota UZ cams are more expensive versus domestic cams because we need 4 cams versus a single cam for domestics. 4 cam for under a grand is a steal for these. The $2000+ cams are billet machined versus Lextreme's re-ground cams that are plenty stong already.
__________________
1998 GS400 VVTi Diamond Pearl White. Tein Flex coilovers, Figs Engineering front caster arm sphericals, rear knuckle sphericals, front/rear end links. TRD sway bars, TOMS 6-link kit, Ikeya Formula rear upper arms, HKS hi-power axle back.
Soon to be supercharged and intercooled...
  #12
Old 04-22-2011, 03:47 PM
4U2QUIK 4U2QUIK is offline
Approved Vendor
Default
as for raising the rev limit, I've been doing research, and I may have found a way to change the rev limiter, but there's problems with doing this. Whatever your last fuel and spark bins are, the get extended from the original rpm to the new one. Whic h could be problematic.
  #13
Old 04-26-2011, 08:39 AM
taka21 taka21 is offline
2nd Grader
Default
i see said the blind man
Quote:
how so? and how are you managing to find this info?
  #14
Old 04-26-2011, 12:35 PM
Approved Vendor
Default
it's mostly personal knolege acquired over the years from working with electronics and electronic componant developement.
  #15
Old 04-26-2011, 01:06 PM
2nd Grader
Default
oh ok i thought you might have found a way to read the lexus ecu , and maybe make it tunable like the nissan and honda ecu's
  #16
Old 04-26-2011, 02:39 PM
Approved Vendor
Default
kinda like nissan, but much more complicated. I'm going to try to use romreader to load the bins.
  #17
Old 06-16-2011, 05:06 PM
Armed_N'_Hammered Armed_N'_Hammered is offline
2nd Grader
Default
Can anyone tell me how much power a 1uz with stock internals would hold?
89-94 1uz:
95-97 1uz:
Thanks.
  #18
Old 06-16-2011, 05:11 PM
spf_lexus's Avatar
Bachelor
Default
Quote:
89-94 1uz:
500BHP (trans will fail around 350 whp)
Quote:
95-97 1uz:
300-350bhp (weak rods, trans will fail around 350whp)
__________________
  #19
Old 06-16-2011, 05:12 PM
spf_lexus's Avatar
Bachelor
Default
I hate the lack of edit post! 95+ engines have 300-350whp not bhp (sorry about that)
__________________
  #20
Old 06-16-2011, 05:45 PM
2nd Grader
Default
Thanks SPF
What exactly would fail on these transmissions?
I just finished my trans build last month. Added a cooler, ipt valve body, and lextreme TC. Some of the supra forum members suggest this transmission would be good for 600bhp if raybestos plates were added.
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
