| Fuel, Ignition, Air, & Tuning (FIAT) (Members Only) Stand Alone ECU, Piggy Back ECU, Wiring, Tuning, Injector Upgrades, Air Fuel ratio, Fuel Pump, Ignition, FMU, FPR and any engine electrical/fuel component relative topics. |
Thread Tools | Display Modes |
#1
Can someone give me contact details for anyone that sells carburettor manifolds for the 1uz. I have googled to no avail. Apparently common in NZ speedway.
I do not require a lecture on EFI versus carb but would apprieciate help. Thanks |
#2
Try Madphil of Marx Motorsport: http://www.marxmotorsport.com/
He runs a 1UZ NZ stockcar with a CSL Cams inlet manifold. You should be able to look at some pics on his site. Here's the spec: http://www.marxmotorsport.com/team/53a.html with his email addy at the bottom. CSL Cams. Address: 53 Bourke St Palmerston North. Phone number: 0-6-356 3700 Apparently Danby Machine & Development Ltd, are another source +64 7 868 8284.
__________________
High mileage, low compression, and sometimes not firing on all cylinders, just like my cars..... New Daily Driver (Ferrari 550 Maranello) Supercharged Supra Project BMW V12 Project 2JZ-GZTE Project Last edited by cribbj; 04-14-2011 at 03:51 AM. |
#3
people keep asking me about carbs on a 1uz, I just keep on saying "fail". What's with the obsession in taking giant leaps backwards?
__________________
Buy your 1UZFE adaptor plates here! |
#4
They're simple.
A 4bbl Holley, a Ford EDIS8 ignition, 4-6 wires to hookup, and you have a running engine.
__________________
High mileage, low compression, and sometimes not firing on all cylinders, just like my cars..... New Daily Driver (Ferrari 550 Maranello) Supercharged Supra Project BMW V12 Project 2JZ-GZTE Project |
#5
Thanks Cribbj
Thats all the info I needed...... 4u2quk, Let me quote Plato- "Wise men speak because the have something to say; Fools speak because they have to say something." |
#6
Touche'
Quote:
already a big edis fan here. Just not a carb fan.
__________________
Buy your 1UZFE adaptor plates here! Last edited by 4U2QUIK; 04-14-2011 at 05:30 PM. |
#7
i need to know more about this "Ford EDIS8 ignition"
will i just need the edis8 and a crank trigger wheel and sensor?? thanks in advance for response |
#8
it's not that carbs are that good, it's just that the factory ECU is incredibly BAD.
__________________
1996 LS400
#9
don't get me wrong i know all about efi and i would rather have an efi engine. for me a 1uz with a carb sitting on the top looks amazing. and the sound of air traveling through the barrels.....
its something i must do. |
#10
Quote:
Then of course you'll need either a carb or a fuel injection setup to get fuel into the motor. I like the EDIS8 and carb setup because it's so simple, and it just works. Great for breaking in a motor.
__________________
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
