Lextreme: Lexus-Toyota V8 Forum
Go Back   Lextreme: Lexus-Toyota V8 Forum > V8 Performance Tech > Diagnostic & Repair Tech > Repair & Maintenance Tutorials (DIY)
Custom Search
Repair & Maintenance Tutorials (DIY) This sub forum is to help newbies or veterans on basic repairs and maintenances. If you have repair tutorials please post them here.
Reply
Thread Tools Display Modes
  #1
Old 06-23-2010, 02:11 PM
Bighen Bighen is offline
Kinder
Default how do you repair a cylinder with low compression
can someone send me a diagram on a cylinder head for a 91 ls 400. How can you repair a cylinder with low compression?
  #2
Old 12-04-2010, 01:49 PM
XR8tt's Avatar
XR8tt XR8tt is offline
Moderator
Default
You've got a combustion leak..
It's either a leaking head gasket.. Or through the valves.. One way to check if it's down through the rings, is to squirt about 5 or 6 cc [teaspoon] through spark plug hole. Turn engine over a couple of times.. Then check compression.. If it rises alot it's leaking down through rings..
Check to see there is a tight valve clearance holding the valve open ??
Check clearance when lobe on the cylinder is facing up...
__________________
When capacity isn't enough?
Forced induction....
  #3
Old 02-13-2011, 02:34 AM
sideshow sideshow is offline
Bachelor
Default
goto your local auto parts shop and buy a can of compression
__________________
www.sideshows.net.au
  #4
Old 02-13-2011, 04:48 AM
samsdad's Avatar
samsdad samsdad is offline
5th Grader
Default
Quote:
I sent the work experience boy off once for a tin of compressed air.. He came back with a Truck air tank. Later sent the same guy out for a long weight. He went across the road to the pub and won $700 on the pokies and took us all out for dinner. I later suggested to the boss that we should see if he could get a skyhook. My workmate got all upset as he knew someone that did get one (a sky hook). That person that got one was me and my boss (at the time) was not too impressed with the big bill from Sikorsky Helicopters.. I got him a hook from a Sky Crane helicopter...10K USD thank you at the time..
On subject you either have a burnt valve or rings gone.. Time to freshen the motor up
__________________
1992 Toyota Hilux Surf 2 door "Wide body" 1UZ-FE Auto. (Daily drive)
1994 Toyota Surf 3.0TD Auto (Wifes drive)
1981 RN40 Hiliux.. UZ is Coming (it's like Christmas)
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
