Lextreme: Lexus-Toyota V8 Forum
Go Back   Lextreme: Lexus-Toyota V8 Forum > V8 Performance Tech > V12 Engines
Custom Search
V12 Engines Here is your chance to learn more about the world V12 engines.
Reply
Thread Tools Display Modes
  #1
Old 06-21-2010, 01:35 PM
MitchP's Avatar
MitchP MitchP is offline
1st Grader
Default 1GZ-FE Part Numbers - Please Sticky!!!
1GZ-FE Part Numbers can be found at this website:
http://www.megazip.ru/ru/auto/toyota/view/465/4177
All of the part numbers match up to the ones I have gotten from a source here at Toyota here in the US and the correctness of the photos makes it look legit.
Hope this helps out!!! I am stoked that I can get parts for the monster!!!
Interestingly, there are prices quoted in Rubles. Looks like a complete long block goes for 528,758 rubles. ($17K USD) I wonder how much shipping from the RU would be???
  #2
Old 06-21-2010, 02:16 PM
cribbj's Avatar
cribbj cribbj is offline
"Supra" Moderator
Default
Stickied (or Stuck)!
__________________
High mileage, low compression, and sometimes not firing on all cylinders, just like my cars.....
New Daily Driver (Ferrari 550 Maranello)
Supercharged Supra Project
BMW V12 Project
2JZ-GZTE Project
  #3
Old 06-22-2010, 01:50 AM
Crambo Crambo is offline
2nd Grader
Default
I've been using ToyoDIY.com, even my local dealer is using this instead of the EPC.
  #4
Old 08-06-2010, 02:19 PM
sniper's Avatar
sniper sniper is offline
Super Moderator
Default
ToyoDIY doesn't work for me anymore. This is a life saver, THANKS!
__________________
/'_-Madhav-_'\
'02 S2000
1GZ V12 for sale. PM for details
  #5
Old 09-22-2010, 05:39 AM
spork2367 spork2367 is offline
Kinder
Default
Good info. I just bought one of these motors.
  #6
Old 02-15-2012, 06:03 AM
jameschia2722 jameschia2722 is offline
Kinder
Default
Hi, may i know where to get 1GZ fe oem ECU? i have an bare engine without ecu. Any idea anyone?
  #7
Old 02-16-2012, 01:32 AM
2nd Grader
Default
Jap Importers should be able to get them off Yahoo Auctions Japan.
If you go with stock ecus you will need the Drive by wire throttle pedal (these are harder to find than ecus),
no other DBW pedal matches these ecus.
Aftermarket ecu and other throttles might be a better way to go.
  #8
Old 05-02-2012, 12:12 PM
Louis Louis is offline
Kinder
Default
Or you could get a spitronics aftermarket. Fantastic job of work.
http://www.spitronics.co.za/cms/
Forex: $US1 = ąZAR7,8
  #9
Old 05-28-2012, 12:56 AM
redrocco redrocco is offline
2nd Grader
Default
The 1GZ has 6 coils, part number 90919 02213. Two of these coils were also used on the 1995+ 5E-FE engine. I pulled a pair from a Paseo at the junk yard the other day and they are the same thing. The two plug wires are even the same as the 2 shorter V12 wires. At $5 a pair for used OEM I plan on stocking up next time at the junk yard.
  #10
Old 05-28-2012, 07:35 AM
4U2QUIK 4U2QUIK is offline
Approved Vendor
Default
looks like the same coil pack as some of the earlier v6 tundras.
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
