Lextreme: Lexus-Toyota V8 Forum
Go Back   Lextreme: Lexus-Toyota V8 Forum > V8 Performance Tech > Diagnostic & Repair Tech
Custom Search
Diagnostic & Repair Tech HELP! My car is not running right. All about Natural Aspirated OEM Lexus/Toyota V8 Powertrain. Post your N/A car problems here.
Reply
Thread Tools Display Modes
  #1
Old 11-21-2008, 12:21 PM
3barboost 3barboost is offline
1st Grader
Default When an alternator dies what actually has failed ?
Hi all
When a round plug (early models) alternator fails - what has actually "died" ? is it a simple and obvious thing like a burnt diode ? circuit board melted ? brushes stuck or worn out ?
My alternator no longer charges and they are fairly scarce on the ground this end of the world - any ideas what other toyota models fit ? I dont want to mess too much with pulleys and there spacing etc - the wiring can be redone
thanks for the help !
__________________
Auto Rotor opcon 3150 supercharged 1UZFE in a Mazda MX5
  #2
Old 11-21-2008, 12:26 PM
Lextreme's Avatar
Lextreme Lextreme is offline
Just call me "Lex"
Default
http://www.lextreme.com/alternator.html IC Regulator is the most common problem and contacts would be the next.
__________________
* 1995 SC470TT VVTi - Twin Turbo 4.7L Iron Block at work
* 1995 LS520 - 5.2L Stroker with MeisterR Coil Overs and G35 19s
* 1995 Previa - Supercharged Previa
  #3
Old 11-21-2008, 12:36 PM
1st Grader
Default
is the IC repairable ?
and what alternator fits from other toyotas ?
__________________
  #4
Old 11-21-2008, 03:26 PM
Lextreme's Avatar
Just call me "Lex"
Default
I think Supras alternators are very similar. Here is an article that might help. http://www.lextreme.com/Lexus-Alternator.html
__________________
  #5
Old 11-21-2008, 07:59 PM
Muzza_NZ Muzza_NZ is offline
4th Grader
Default
It is very easy to replace the IC regulator if the brushes and rectifier diodes are in good condition. The IC reg is a standard Nippon Denso (ND) part (common to most of their alternators) and readily available. If you type the part number into google, you'll find they're about $30USD direct from China.
Many honda and other Toyotas that use ND alternators have the same reg. Just check their output voltage rating (once again a google search) and excitation current rating.
  #6
Old 11-22-2008, 10:04 AM
1st Grader
Default
Ok I pulled the alt off and decided to have a look see
I found the commutator had worn through the copper to an insulated area underneath !
I have never heard / seen of this before
what type of mileage would it take to wear that out ?
I assume that there is no practical means of diy repair ?
__________________
  #7
Old 11-22-2008, 09:39 PM
madmont madmont is offline
3rd Grader
Default
Mine is worn like that but not so bad. I recently replaced the regulator which was not working properly. They are as muzza said a ND part and fitted to other alternators as well.
__________________
jealousy is a curse
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
1992 Lexus SC 400 what to look for? ahardy4 Diagnostic & Repair Tech 1 11-02-2006 11:35 AM
Classifieds. Pro Lexus-Toyota V8 OEM & Performance Parts Classified 0 06-01-2006 06:13 PM
1uz into VK help. Mugshot Swap, Conversion, Transplant, Specialty Vehicles & Project Diary (Members Only) 12 04-11-2005 04:32 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
