Lextreme: Lexus-Toyota V8 Forum
Go Back   Lextreme: Lexus-Toyota V8 Forum > V8 Performance Tech > Swap, Conversion, Transplant, Specialty Vehicles & Project Diary (Members Only) > Swap Projects/Worklogs/Diary
Custom Search
Swap Projects/Worklogs/Diary Here is a section dedicated for your on going project.
Reply
Thread Tools Display Modes
  #1
Old 11-15-2016, 10:36 PM
whottwally whottwally is offline
Kinder
Default Twin Turbo 1UZ Soarer Dragcar
I thought it was time to share my Project with the world of Lextreme from down here in Christchurch New Zealand.
I always had a dream of building a Toyota Soarer drag car what eventuated was a lot more radical than first planned.
I had trouble acquiring a donor car to start the build with so instead with the help of a boat building friend I managed to get hold of a car I could take a Fibreglass mould off and so it began.
Once the body was built we started to plan and acquire parts and steel for the rest of it. We ended up buying a steel Docol R8 the new alternative to Chrome Moly.
9 months after the first piece of chassis was cut the car made the track for the first time.
Specs.
Stock Standard 1uz long engine
Custom Box top intake manifold
Siemens 212lb/hr Injectors
Aeromotive Mech Fuel pump
Methanol
2UZ COPS
Twin Biagio turbos specs unknown
Link G4 Thunder ECU
Powerglide Trans
Nine inch full floating diff
Have run a best time of 10.045 and a best MPH of 129 so far with only 3 race meeting competed and still working our way though the Tune.
Scott
  #2
Old 11-16-2016, 04:55 AM
cribbj's Avatar
cribbj cribbj is offline
"Supra" Moderator
Default
Well done!!! Thanks for sharing.
What sort of boost are you running?
__________________
High mileage, low compression, and sometimes not firing on all cylinders, just like my cars.....
New Daily Driver (Ferrari 550 Maranello)
Supercharged Supra Project
BMW V12 Project
2JZ-GZTE Project
  #3
Old 11-17-2016, 10:45 PM
Kinder
Default
At the moment we are having a back pressure issue with turbine housings and is seeing up to 15psi under load. We are still working through the tune and have it pretty clean up till 6000rpm.
Reply
Tags
dragcar, methanol, soarer, twin turbo
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
