Very weird electrical issues
Discussion in 'Diagnostic & Repair Tech' started by Gazeebo, Jul 29, 2018.
  1. Gazeebo
    Gazeebo New Member
    Jul 29, 2018
    8
    1
    Gender:
    Male
    Hello everyone:
    I currently have a 90 LS400 with a mysterious code 42 (speed sensor 1). I have replaced the speed sensor, instrument cluster and ECU with no avail. Current symptoms are:
    Code 42 (O/D light blinking)
    Dead speedometer
    Dead Odometer
    Dead trip meter
    Gasoline smell
    Very sluggish performance in gear (not in park or neutral)
    Erratic shifting
    I am seriously thinking it's a wiring issue because car had 2 fuses (GAUGE and CIG) with higher than factory amp rating, I changed them to factory spec fuses and now the battery dies overnight. Any idea what issue this can be? possible wire touching and shorting out?
    Thank you very much for any help everyone.
  2. gloverman
    gloverman Well-Known Member
    Oct 15, 2004
    2,752
    68
    48
    mechanic
    Hamilton. New Zealand
    Did you change a two pin or three pin speed sensor?
  3. Gazeebo
    Gazeebo New Member
    Jul 29, 2018
    8
    1
    Gender:
    Male
    This exact one (3 pin)
  4. gloverman
    Oct 15, 2004
    2,752
    68
    48
    mechanic
    The speedo clusters are quite prone to failing. I would be checking the signal is getting to the cluster first and work from there.
  5. Gazeebo
    Gazeebo New Member
    Jul 29, 2018
    8
    1
    Gender:
    Male
    I replaced my original cluster with another one working and didn't work. How can I test the signal? I'm pretty bad when it comes to wiring and electricity in general.
