Under the timing belt two metal pieces coming off the block
Hatchet man
Someone dropped a bolt down my timing belt area when I started it the bolts sheared off the two metal things coming off the block what are those for
Sounds like rotten luck! Would you have a photo of that? Might help with identifying what you mean.
when I go to put a picture on it tells me it's too large but if you coming out of the block or two half inch long metal pieces they look like it holds the belt from being able to jump teeth
Sorry, can't really picture in my head what those are. Would you be able to use some photo software to decrease the photo so you can upload it here?
Are you referring to the pieces that normally sit under the crankshaft timing belt pulley? If so they are there for help fitting belt. As long as oil pump isnt cracked i would say it would be fine without them.
