toyotav8.com's R154 to 1uz adaptor install
Discussion in 'Drivetrain (Members Only)' started by 4U2QUIK, Jun 24, 2012.
  1. black_LS
    black_LS New Member
    Jun 25, 2013
    27
    1
    Toronto
    Great, thank you.
  2. AutoLuxLexES
    AutoLuxLexES Member
    Mar 15, 2011
    43
    6
    student
    in the desert of....
    Hello,
    I see that you are very familiar with 1uz/r154 conversions and I am wondering if you know how much clearance there is between the auto bellhousing and transmission tunnel on the sc400?
    The reason I ask is because I wonder if my r154 hydraulic issues are related to the bleed line exiting the top center of the bellhousing getting kinked between bellhousing and transmission tunnel.
    Or if it could possibly be that I need a clutch master cylinder with a 3/4" bore for the tilton 61-400 tob? Because currently the clutch pedal is too soft for my liking
    Thanks
    Charley
  3. 4U2QUIK
    4U2QUIK Approved Vendor
    Oct 22, 2009
    1,184
    1
    38
    machinist
    Modesto california
    Home Page:
    if it's too soft for your liking (like my supra is to me) then you need to go to the willwood or tilton 3/4" bore.
  4. Corax
    Corax New Member
    Sep 22, 2017
    1
    1
    Gender:
    Male
    wrench monkey
    PNW, USA
    because photobucket broken links suck ;)
    (not my kit, but I wanted to see the pics in context)
    First off here's the t56 throwout bearing
    [​IMG]
    On the left hand side it has a slip fitting that is retained by a roll pin
    [​IMG]
    remove the roll pin and the big orange gm fitting slides right out.
    Go ahead and toss this piece as it's useless for this swap.
    [​IMG]
    now use the slip fitting that came with the kit and slide it into the t56 throwout bearing.
    Then replace the roll pin.
    [​IMG]
    [​IMG]
    now remove the fitting on the other side and replace with the fitting that's shrink wrapped to a piece of cardboard with a crush washer and be sure to use the crush washer or else IT WILL LEAK!!!
    [​IMG]
    [​IMG]
    Now you're done with setting up the t56 bearing for use with the braided steel clutch lines.
    Chapter II
    Unfortunately I do not have any pics right this second for this section. But I'll post the instructions now and the pics later.
    Basically you cut the guide tube that's on the bearing retaining plate off flush with the plate.
    CHAPTER III
    Remove and toss all of this stuff from the automatic.
    ABSOLUTELY DO NOT USE THE SPACER FOR THE AUTOMATIC FLEXPLATE BEHIND THE FLYWHEEL!!!!!!
    ABSOLUTELY DO NOT RE-USE THE FLYWHEEL BOLTS FROM THE AUTOMATIC FLEXPLATE!!!!!
    [​IMG]
    Now here's the back of the crank. Your pilot bearing goes in here.
    [​IMG]
    next install the flywheel with your new flywheel bolts that you just bought. You should probably get them from summit racing.
    here's the link http://www.summitracing.com/parts/ARP-203-2802/
    [​IMG]
    and here's the flywheel installed with the ARP bolts I bought from summit.
    [​IMG]
    Install your clutch
    With the cast flywheel there are several options for clutch setups. Typically I suggest either using the 3SGTE MR2 21 spline clutch kit or the 1990 4runner clutch kit because both clutches work complete as a set with this flywheel.
    [​IMG]
    Install your pressure plate, and now you're engine is prepped for install!
    CHAPTER IV
    [​IMG]
    Once again I'm a little short on pictures, but basically you drill two holes for your clutch lines to go out the bellhousing and then bolt everything together Like so.
    [​IMG]
    Now that you've accomplished bolting it together you're done.
  5. 4U2QUIK
    Oct 22, 2009
    1,184
    1
    38
    machinist
    Modesto california
    Home Page:
    THANK YOU SIR!!!!
  6. Thobias H. Fredriksson
    Thobias H. Fredriksson New Member
    Nov 4, 2017
    2
    1
    Gender:
    Male
