Toyota/Lexus ECU reprogramming
Discussion in 'Trade' started by George_R, Oct 20, 2015.
  1. George_R
    George_R Member
    Sep 13, 2010
    850
    2
    18
    Gender:
    Male
    DSP engineer
    Russia, Moscow
    Home Page:
    I'm starting to offer new service, in addition to immo off (see http://www.lextreme.com/forums/showthread.php?t=16344)
    Currently supported are
    Lexus LS430 / Toyota Celsior UCF30 , 6a/t only
    Lexus GS430 / Toyota Crown Majesta UZS186, 6a/t only
    Lexus IS250 / Toyota Mark X
    Toyota Tundra 5.7 , all years
    Toyota Sequoia 5.7 , all years
    With more to come. So far I can only do ECUs dated from 2003 onwards
    OLDER ECUs ARE NOT SUPPORTED
    ECU should be sent to me for reflashing
    Currently available options:
    -power/torque increase
    -disabling catalytic converters monitoring, sub o2 sensors, charcoal canister monitoring
    -disabling a/t related DTCs and fail safe modes for manual transmission install
    power/torque increase is achieved by changes made to the following parameters: (ignition advance map including base calibration, max retard values, and THA/THW correction as well as adjustment per VVT position ; fuel map including base calibration and dynamic enrichment values; changing VVTi base maps)
    Price is $400 USD for any list of supported options
  2. 4U2QUIK
    4U2QUIK Approved Vendor
    Oct 22, 2009
    1,183
    1
    36
    machinist
    Modesto california
    Home Page:
  3. George_R
    George_R Member
    Sep 13, 2010
    850
    2
    18
    Gender:
    Male
    DSP engineer
    Russia, Moscow
    Home Page:
    A friend of mine actually does this to *OLDER* ECUs which I can not care less for
    These use 8-bit Motorola-derived processors
    Newer ECUs like those for 1UZ vvti and 3UZ (2000-2003) use 16-bit controllers, but these seem to be mask ROM programmed (i.e. one time programming that is part of crystal manufacture process). Apparently these can be run off external memory, like this is done in my Tom's tuned ECU for 1uz-fe vvti. But the method ultimately needs desoldering of old processor and installing some add-on board.
    Even if someone manages to read factory firmware from such ECU, I would not bother even trying to do that lot of precise handwork. In fact I even don't rely much on my Tom's ECU and always have a spare factory ECU in my car.
    What I offer for newer ECUs is purely software thing and that's reliable enough to me.
  4. George_R
    George_R Member
    Sep 13, 2010
    850
    2
    18
    Gender:
    Male
    DSP engineer
    Russia, Moscow
    Home Page:
    Prices went down
    $250 for reprog now
