Boosted2.0 (Dave)
Nice, you have any dyno numbers on that thing? The all trac?
Why did you switch to A2A?
Don't know if you've seen the original setup with this bracket, so here's a pic.
There is three ways to intercool that stand out in my mind.
1. Route the pipe under the driver's headlight to a FMIC behind the bumper, then route pipe under the pass side headlight to the engine intake.
This would be a more common setup I would guess people would use.
2. Clock the supercharger snail so that it points towards the pass side of the car. Route the pipe straight across the engine, under the pass side headlight to a FMIC (same side in and out) and then double back to the intake.
I don't think that the piping would be much shorter, but shorter none the less. I suppose the charge might pickup some extra heat as it goes past the engine. Also need to keep in mind the mech fan I am adding.
3. Same as above but fit an air to water intercooler where the stock air box is (pass side, behind the headlight) then straight to the intake.
I think #1 would be the longest piping, #2 piping would be shorter, #3 shortest piping.
I don't know for sure if the A2W intercooler would fit in the space of the factory air box or not. The radiator should fit in front with out any problems, there is plenty of room behind the bumper despite what it looks like. Pump and lines routed where needed.
I think that regardless of which way is used, custom piping will be needed. A universal kit may have enough of the right parts to work, but it would be hard to determine for sure until the kit was in hand.
Also, the small outlet diameter of the V-9 (2.5 inches) will be an advantage. Running 2.5 inch intake pipe will give me more options, with less body modifactions than a larger pipe. I would likely use the 2.5 all the way to the maf, at the maf I would need to upsize to 3 inches.
As far as my vibration. I still have some, but I think its all vibrations that where already there. I've had some problems with the tires I put on it, they have awsome traction but ride like crap. Plus I still need to change the motor mounts, I suppose they are probably worse off now that they were stressed a bit while removing the trans.
Please, all comments welcome and needed.
Khris
PS Dave. Lucky me, Prius classes today, tomorrow, and Thursday. 072 and 073 I think.
