kc95sc400
- 524
- Charlotte, NC
Guys,
A couple of updates, comments and a couple of questions for Lex.
Updates: Yesterday, I installed my torque converter and my LSD modded diff. Also rear main seal, transmission front pump seal, and my transmission mount. Sorry, no pics. I wasn't planning on doing the installation till Friday so I didn't bring the camera. It was slow at work so I decided to go for it.
Installation went pretty smooth, my car does have some corrosion but I only broke one bolt.
After install, I now have a horrible bearing growl that only happens when I accelerate fairly hard from a stop. I am about 95% sure that the noise is coming from the center driveshaft bearing. I ordered one and should have it and install it tommorow.
I haven't really pushed too hard yet, I figure the TQ needs some break in and with the noise I have I've been taking it easy, but so far I am not sure I am impressed by the torque converter. Just not quite the neck snapping difference I was hoping for. It drives differently for sure, just not too impressed yet. I will likely play with the trans throttle cable some to taylor my shift points.
After I replace the bearing, I will push it some to see what it can do, then maybe I'll be more impressed. I hope I'm correct on the bearing and it's not the LSD making noise.
Questions for Lex: Will the driverside coil pack need to be relocated? The bolts needed will be stock length bolts plus 1/4 inch, correct?
Comments: I am excited about getting the bracket soon. It will be a huge step. It's very hard to visualize what all needs to be done without having the bracket in its place. I don't know about the rest of you, but once I get the bracket (and a means to delete the hydro fan) I will likely bolt it on and leave it even if I'm not ready for everything else to go into place.
Khris
Khris
